I have a 2000 Ford Ranger. I am a volunteer fire fighter and in a few months I will be certified to operate lights and a siren on my truck. Does anybody have any experience installing these systems? Is it difficult? I used to work with somebody who is a diesel mechanic... he admits he has no experience with this equipment, but says he can "probably figure it out." Should I trust him, or should I pay the police supply company $75/hr to install it?
First you have to know what you want to run, then you have to know where you want everything mounted. Then you have to know how much power what you are running will draw! (I burned, flamed broiled an illuminated 15 amp toggle switch by not knowing how much power my lightbar was pulling!) Now I am running 4 55 watt rotators, and two 50 watt halogen flashers, as well as the 27 watt takedowns & 27 watt flashers. Along with the Federal signal 100 watt siren, and a mobile radio that has an output strength of 50 watts.
If you need any help, I did all of my own wiring and my setups. You can see what I'm talking about below on my website.
just wnated to warn you. Be careful where and how you wire your equipment. My brother in law and myself just finished his 97 f-150. Apparently we used the wrong ground and it started backfeeding (according to the dealer) into the computer(s). This was ( and still is) causing the truck to stall when you let of the accelarator. We changed grounds and it is still doing it. I have done several installations (from personnel vehicles to our fire and police depts) and this is the first time this has happened. Another thing you rmight want to consider is putting all your equipment on relays and circuit breakers (available from galls or your local Napa). This will prevent you froom running down your battery if you forget to turn everything off when you get to where your going.
