oil leak/ engine removal.
Old 08-26-2008, 03:22 PM
79f-250custom's Avatar
79f-250custom
79f-250custom is offline
was walking to my truck the other day and noticed that i had a pretty good oil leak going on. looks like the oil pan gasket or the rear main seal cant really tell. my ? is do you have to pull the motor to get the oil pan out of the truck? and if i do have to pull the motor should i just put a complete gasket set on the motor?
thanks guys
Mitch
Old 08-26-2008, 03:34 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Yep, the engine needs to come out or at least be lifted about a foot. Same amount of work as pulling it IMO.
Take a look into the engine valley. If a leak occurs there it will show up as a rear main seal leak. BTW: Rear main seals are not prone to leaking.
Old 08-26-2008, 03:39 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Old 08-26-2008, 04:30 PM
sbxworship's Avatar
sbxworship
sbxworship is offline
IPR perhaps? You may want to check your HPOP level...
Old 08-26-2008, 04:40 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
X2. Check the valley of death! (first)
There is a hole in the back of the block, Fluids make there
way down from it.
Bill
Old 08-26-2008, 04:45 PM
cchildress's Avatar
cchildress
cchildress is offline
I had that problem were I thought it was the rear main seal but like what was said look in valley. I pulled the trans and replaced the seal and still had the problem it ended up being the turbo orings and I pulled the tranny for no reason!! So look in the valley first!!!!
Old 08-26-2008, 04:56 PM
Action4478's Avatar
Action4478
Action4478 is offline
..Ouch...
Old 08-26-2008, 04:59 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
Originally Posted by Action4478
..Ouch...
Double Ouch
SOAB!
Bill
Old 08-26-2008, 05:59 PM
cchildress's Avatar
cchildress
Ya it sucked bad but you either learn the hard way or get on here and do some research and learn from the best. Me being hard headed thinking that that has to be what it was and boy was I wrong and PI***D OFF!!!!! But I got it figured out and now its good.
Old 08-26-2008, 06:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
90% of the time its the turbo pedastool, whether its the o-rings or the ebp valve its in the pedastool. i have only replaced a small handful of rear main's on 7.3's they just dont go bad. and the oil pan will rot out before the silicone sealant lets go.
Old 08-27-2008, 02:57 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Question
are there any kit to fix the o-rings or the ebp valve its in the pedastal? part #?
Old 10-10-2008, 10:33 AM
79f-250custom
well my truck still leaks oil like a sun of a gun and i still cant find a oil leak. i looked in my vally and it looked wet but no standing oil. is there anything else behind the motor that could be leaking?
thanks guys.
Mitch
Old 10-10-2008, 10:43 AM
Action4478's Avatar
Action4478
Oil rail plugs on the rear of the heads ,,one on each side ...
They are also on the front of the heads ,too...
Old 10-10-2008, 02:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
BUMP BUMP
Old 10-10-2008, 02:16 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
I know the pedestal o-rings are standard rings the EBP valve I am not sure. I would imagine they are no different than the ones at the hardware store.
Quick Reply: oil leak/ engine removal.
