oil leak/ engine removal.
was walking to my truck the other day and noticed that i had a pretty good oil leak going on. looks like the oil pan gasket or the rear main seal cant really tell. my ? is do you have to pull the motor to get the oil pan out of the truck? and if i do have to pull the motor should i just put a complete gasket set on the motor?
thanks guys Mitch |
Yep, the engine needs to come out or at least be lifted about a foot. Same amount of work as pulling it IMO.
Take a look into the engine valley. If a leak occurs there it will show up as a rear main seal leak. BTW: Rear main seals are not prone to leaking. |
Take a look here:
https://www.ford-trucks.com/forums/7...e-oil-pan.html and here: 7.3 powerstroke oil pan solutions ................ save $2k!!!! |
IPR perhaps? You may want to check your HPOP level...
Originally Posted by Cuda_jim
(Post 6484623)
Take a look into the engine valley. If a leak occurs there it will show up as a rear main seal leak. BTW: Rear main seals are not prone to leaking. There is a hole in the back of the block, Fluids make there way down from it. Bill |
I had that problem were I thought it was the rear main seal but like what was said look in valley. I pulled the trans and replaced the seal and still had the problem it ended up being the turbo orings and I pulled the tranny for no reason!!:-banghead So look in the valley first:)!!!!
Originally Posted by cchildress
(Post 6484828)
Originally Posted by Action4478
(Post 6484868)
..Ouch...:-banghead
SOAB! Bill |
Ya it sucked bad but you either learn the hard way or get on here and do some research and learn from the best. Me being hard headed thinking that that has to be what it was and boy was I wrong and PI***D OFF!!!!! But I got it figured out and now its good.
90% of the time its the turbo pedastool, whether its the o-rings or the ebp valve its in the pedastool. i have only replaced a small handful of rear main's on 7.3's they just dont go bad. and the oil pan will rot out before the silicone sealant lets go.
:-hijacked are there any kit to fix the o-rings or the ebp valve its in the pedastal? part #?
well my truck still leaks oil like a sun of a gun and i still cant find a oil leak. i looked in my vally and it looked wet but no standing oil. is there anything else behind the motor that could be leaking?
thanks guys. Mitch |
Oil rail plugs on the rear of the heads ,,one on each side ...
They are also on the front of the heads ,too... |
Originally Posted by RÖENTGEEP
(Post 6487933)
I know the pedestal o-rings are standard rings the EBP valve I am not sure. I would imagine they are no different than the ones at the hardware store.
