Sponsored by: Real Truck
First Post - Keyed Power
Old Aug 25, 2008 | 01:58 PM
OSH4105's Avatar
OSH4105
Hi All,
I've been lurking here for quite a while, gathering tons of useful info, and now I have a question.
I have a 2008 F-250 Supercab, Gas Engine.
I am hooking up a plow and need a keyed power source. Searches here describe a blue / white wire in the steering column or under the instrument cluster. Well, try and try again, I can't seem to find this wire. Does anyone have any suggestions regarding this or any other source of power?
Old Aug 25, 2008 | 10:49 PM
ReAX's Avatar
ReAX
You can use the radio to trip a relay. Or you can use a meter to find the wire under the dash.
Old Aug 26, 2008 | 09:21 AM
OSH4105's Avatar
OSH4105
Thanks for the reply ReAX,
I can always tap into the radio circuit but I was hoping to use the dedicated wire that Ford supplied for this purpose. I believe this may be a new feature on the 08 models.
Has anyone else had luck finding this wire?
Old Aug 26, 2008 | 09:23 AM
riggz's Avatar
riggz
I'm guessing you don't have the upfitter switches? Those are only powered when the key is on. Might be something to look into.
Old Aug 26, 2008 | 06:55 PM
F350-6's Avatar
F350-6
They usually zip tie them in place up a ways kind of behind the OBDII connection plug.
Old Aug 26, 2008 | 08:14 PM
rwilimo's Avatar
rwilimo
On pre 08 trucks the white/blue wire is basically over the gas pedal. I would guess that they moved it on the 08's though.
Old Aug 27, 2008 | 01:52 PM
OSH4105's Avatar
OSH4105
Sounds like I'm going to have the dash apart again this weekend.
xaviar
Sep 22, 2021 02:01 PM
kell104
13
May 3, 2013 12:55 AM
SC'79
Feb 26, 2013 11:13 AM
bgrdedf17
Wisconsin Chapter
Mar 10, 2008 07:02 PM
