Sponsored by: Auxito
rear end q.
Old Aug 24, 2008 | 11:04 PM
DJPRacer58's Avatar
DJPRacer58
rear end q.
i got a 99 f150 lariat 5.4L extended cab wit a 3.73 LS rear and the limited slip stopped locking up on pavement. in dirt and gravel it still works but only 1 tire spins on pavement. it drives fine under normal conditions but the last couple of burnouts i did i noticed it. anyone know why this is happening?
thanks
derek
Old Aug 25, 2008 | 06:06 AM
torkum's Avatar
torkum
The problem is too many burnouts Pull the cover off and see whats going on.
Old Aug 25, 2008 | 04:32 PM
DJPRacer58's Avatar
DJPRacer58
thanks, where should i start looking at. theres a lot of small parts in that pic.
Old Aug 25, 2008 | 04:44 PM
Ron W.'s Avatar
Ron W.
For some reason Fords "limited slip" now uses steel and friction plates much like your automatic transmission, odds are your friction plates are "FUBAR".
Check the aftermarket and see if you can come up with an all steel set up, it'll live longer. The all steel "Detroit Locker" in my 75 GMC 4X4 never failed.
Old Aug 27, 2008 | 03:43 PM
DJPRacer58's Avatar
DJPRacer58
thanks, that sounds like it might be the problem. i got to look at it. i was looking online about the detroit locker and saw they make a limited slip diff called a detroit true track. i only problem is i cant find where to buy them for the 9.75rg
Old Aug 27, 2008 | 04:25 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Have You Changed The Gear Lube In The Differential (rear End) Lately Or At All? You Should Change It Periodically (60k Or So). If You Haven't, I Would Do That First. Use 75w140 Synthetic Gl5 Rated Gear Lube And Be Sure That You Add Abottle Of Motorcraft Xl3 Fricyion Modifier (very Important). If You Are Still Having The Same Problem After Changing The Gear Lube You Will Probably Need To Fix The Internals. Good Luck, Dan. 1964 Ranchero 302 T10 4speed 8" Rear End.
Old Aug 27, 2008 | 07:47 PM
DJPRacer58's Avatar
DJPRacer58
i had it changed at 110k, it now has 147k. it was done at an express lube when i first got the truck. would they have used that motorcraft stuff u were talking about?
Old Aug 27, 2008 | 08:23 PM
steve(ill)'s Avatar
steve(ill)
if you leave the friction modifier out, you normally have dragging and popping in the rear axle when you turn corners. the clutch wont let go. you wont notice much difference in a straight line.
Old Aug 28, 2008 | 12:52 PM
Parts Guy Wyatt
Former Vendor
They probably would not use MotorCraft. They more than likely used an off brand for it. And they probably didn't even put in the friction modifier.
Old Aug 28, 2008 | 05:08 PM
DJPRacer58's Avatar
DJPRacer58
thanks, so if i do need to rebuild the rear where can i find the aftermarket parts? i looked on google but all i find is info on how they work.
JWC 3
22
Apr 14, 2014 06:58 PM
CTford
Jan 30, 2007 05:40 PM
nowbiteme
1978 - 1996 Big Bronco
Nov 18, 2004 05:30 PM
dassmoof
48
Feb 3, 2004 12:04 PM
93bigbronco
Offroad & 4x4
Jan 23, 2002 03:09 PM
