blinker works, parking light doesn't
Old Jun 19, 2001 | 12:38 AM
murphydo's Avatar
murphydo
The right blinker will blink, but the parking light does not work. they both work off the same bulb. i tried another bulb but it stays the same. now the connection has three wires that goes into a stock looking metal connector. The left blinker connector look to be an after market plastic one. i wonder what should i do to fix it. try re-wiring the old one, or get a new connector.
1987 F150 2wd
4.9L, 4 spd manual
31X10.5X15 BF's ATs
3" suspension lift
163,000 and counting
Old Jun 19, 2001 | 11:34 AM
sparky's Avatar
sparky
Well since the right blinker works the ground for the right side is good. Is the connector corroded? Are you sure the bulb you tried is good?
Try checking for voltage at the contact for the right parking light. Make sure the contacts of the socket are clean. I have seen where the contact spring is a little weak and doesn't push the contact up against the bulb, this means a new socket usually.
The three wires into the socket are the blinker, parking light and ground. Should be black for ground, I cant rememeber the other colors off the top of my head, maybe green for blinker and yellow for parking light?
Anyway if you decided to replace the socket it is easy, just match the wires up.
Good Luck.
Sparky
Old Jun 22, 2001 | 07:29 PM
treefort's Avatar
treefort
Old Oct 7, 2022 | 12:58 AM
markwoten's Avatar
markwoten
Veteran: Navy
Rear Tail light issue.
1987 F150 2wd
4.9L, 4 spd manual
31X10.5X15 BF's ATs
3" suspension lift
I had serious issues with the tail lighting harness on my 79 F150. Best thing I ever did was purchase the Haynes manual for my truck. I had to go hand over hand with it all. My issue was the wiring internally was so corroded that I just replaced it. It found a complete replacement on EBay. You just need to get the book, clear your mind of everything and hit it hard. On the bulbs, I’ve found that the end of the bulb that touches the bottom of the socket didn’t have the raised nipple or point to touch the metal strip. Some Ford bulbs can be installed incorrectly. Just rotate it 180 degrees in the socket. Good luck!!! Get The Book!!!!
Old Oct 7, 2022 | 06:47 AM
projectSHO89's Avatar
projectSHO89
Congratulations, you win the Lazarus award for resurrecting a dead thread! That post was 21 years ago.
Check dates on old threads before posting to an old one.
Old Oct 7, 2022 | 10:39 PM
black & blue 78/9's Avatar
black & blue 78/9
Maybe so but at least they know how to use the search feature.
Old Oct 8, 2022 | 06:13 PM
projectSHO89
Wow! Giving out awards for using Google now?
Old Oct 9, 2022 | 04:41 AM
JWA's Avatar
JWA
Well yes since everyone gets a trophy an award is the least to be done!
williamwilliam
Dec 5, 2021 05:50 PM
rndbroom
Oct 21, 2020 01:07 PM
staysbroken
Nov 22, 2010 04:04 PM
Emporia
Oct 26, 2003 09:30 AM
DS02F250
Mar 1, 2003 11:10 AM
