I have a 95 ranger, 3.0, 4x4 with the 4R44E Trans. Under normal driving conditions it shifts fine but under heavy accelleration to pass or to climb a hill, it shutters trying to shift....like shifting in and out of gear very rapidly. If I let off the throttle and ease into it, then it will shifts fine with no slipping. Is this a solinoid or linkage problem, or the valve body plate and gasket. Help!!!
You should post your questions in one of the tech forums. I'm sure one of the members will be willing to assist you with your problem.
Try posting in this forum,,, Ranger & B-Series - Ford Truck Enthusiasts Forums
