Sponsored by: Real Truck
Outer Dust Seal, Front Axle
Old Aug 26, 2008 | 01:14 PM
skoveng's Avatar
skoveng
Not to hijack the thread, but to get to the inner dust seal you need to remove the axle seal in the steering knuckle to ge the axle out. How in the heck can you remove it easily? I needed to replace ball joints and mangled the axle seal in the knuckle trying to get it out.
Old Aug 26, 2008 | 03:33 PM
Stone Mathews's Avatar
Stone Mathews
I've never done the job, but this is where I'd start!
https://www.ford-trucks.com/forums/3...ll-joints.html
Stone
Old Aug 26, 2008 | 06:55 PM
cgl's Avatar
cgl
Right. That dust seal is pretty much just hand pressed on the axle. The floppy ring is what rides inside the axle tube. What did they expect to happen?!
As for the big metal seal, I just tugged on mine until it slid out. Technically, there are only 6 bolts (not counting Lugs) to get to the axle removal process. @ for the brake caliper and 4 for the hub assembly. Both use the same socket Then you only have the spring clip on the hub lock out and the snap ring for the trust washers... and then it's time!
Old Aug 27, 2008 | 10:14 AM
ironmine's Avatar
ironmine
Stone
RacerGuy's write-up is right on the money. I know from first hand experience.
Well, second hand. I sat in a lawn chair and watched as my teenage son did the job using Racer's guide.
Racerguy
Aug 15, 2023 02:03 PM
wy4525
May 8, 2015 05:27 PM
fmx_freak
Oct 24, 2011 09:24 AM
Rancha9
May 14, 2006 12:09 PM
Kenny
Dec 15, 2003 06:43 PM
