Do any of you guys know the part#s for the auto locking hub gasket, o-ring, and torx bolts? Also the updated dust seal part# between the U-joint and the outer part of the axle tube that seals the shaft off from contaminates. I have searched and I just want to make sure I have the correct numbers, it seems there is more information on the 99-03 4x4 front ends than the 04-07's. Its the truck that's in my signature. Any help would be greatly appreciated. I was about to do ball joints, U-Joints, and all that good fun stuff and I wanted to replace the dust seals, and auto hub gasket and o-ring when I went in.
Yes, and the Locking Hub might just only require an o-ring, I have not disassembled anything yet to see, I am just preparing for it. Tousely's parts list don't include the hub lock o-ring, or at least I didn't see it if they did.
There was another guy on another forum was changeing his hub and bearings with part numbers but I can not seem to find his post now. Sorry so no help here.
Thanks anyway, I am having the same problem. I search and search with no results worth noting. Oh well, I'll call Tousley tomorrow, they are the ones I purchased my head gaskets, oil cooler, and all that from when I did my head studs. So I will call them if no one has the part numbers on here. Thanks again for helping!!
Okay, I found the part numbers for the Yellow O-ring on the Hub/wheel bearing, I have the part number for the axle shaft main seal, and the dust seal. So all I need is the one for the hub lock.
