1973 Ranchero horn problem
Old Aug 9, 2001 | 08:42 AM
bbtkd's Avatar
bbtkd
[font size="1" color="#FF0000"]LAST EDITED ON 09-Aug-01 AT 09:44 AM (EST)[/font][p]Hello - I recently bought a 1973 Ranchero and have noted that with the car off, the horn usually does not work - it just 'clicks' like there is insufficient power. When the car is started, the horn always works fine. I replaced the battery and the solenoid as they were both bad and that fixed the problem I was having starting it.
When I was diagnosing the battery problem, I noted that when I had a battery charger attached, the horn worked but when I removed it or turned it off, the horn again would not work. What should I be checking next - if the car must be running to have sufficient voltage to run the horn? It is not a charging problem since the horn still would not work with the new and fully charged Die Hard battery. Might I have a grounding problem? Thanks in advance for your help!
Tom
Old Aug 9, 2001 | 11:29 PM
bsprowl's Avatar
bsprowl
I believe the horn should not work with the ignition off. If that's correct then the ignition switch is bad. What else works wiht the key off that probably shouldn't?
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 10, 2001 | 12:55 PM
bbtkd's Avatar
bbtkd
[QUOTE]I believe the horn should not work with the ignition off. If that's correct then the ignition switch is bad. What else works wiht the key off that probably shouldn't?
Every car I've ever seen has the horn wired to work with the car off. I cleaned the contacts to the horn last night and it was working with the car off - but that still would not explain why it would usually only work with the car started. Perhaps with the dirty contacts, it took higher current/voltage to overcome the poor connection? If it keeps working, may never know...
Tom
Old Aug 11, 2001 | 04:36 PM
bsprowl's Avatar
bsprowl
Wow, really weird. Never even suspected that a horn would work with the key off and it does on all of our vehicles. Wonder why? No other accessory does. But the lights do also, hmmm ...
Anyway, the horn works OK when on the battery charger; this makes me suspect the horn relay or a bad connection, ie, a connection that's corroded.
Bob
Old Aug 13, 2001 | 08:56 AM
bbtkd's Avatar
bbtkd
I did not realize there is a horn relay - but I'll check that and clean the connections. Thanks!
Tom
Old Aug 13, 2001 | 09:19 AM
OK's Avatar
OK
Mikey Cash
Aug 2, 2013 08:40 PM
txtski
1983 - 2012 Ranger & B-Series
Aug 15, 2012 09:00 AM
txtski
Aug 15, 2012 08:58 AM
ron65
Jun 27, 2009 02:17 PM
QUIKKER347
Electrical Systems/Wiring
Feb 18, 2009 10:01 PM
