Womp womp, NOT romp romp!! please help
Old Aug 22, 2008 | 09:14 PM
greagin's Avatar
greagin
i think my vacuum pump may be going bad. i have a (don't laugh) womp womp womp noise when i am sitting there idling with the brake on thats coming from the passenger side of the engine bay. its worse sometimes with the A/C on but am trying to figure out what it could be. only thing i could think of would be the vacuum pump. anyone else heard/had this happen before?
only noticeable at extremely low speeds (e.g. turning in and out of the driveway, idling at a stoplight, fast food drive thru, etc...). Seems it is definitely coming from the passenger side of engine bay. any help would be appreciated.
Old Aug 22, 2008 | 09:36 PM
empiretc's Avatar
empiretc
turn off the a/c and see if it still does it. the only thing our trucks use vacuum for is the vent door.
Old Aug 22, 2008 | 09:40 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Good post David. You have been here a long time helping folks. It is now my mission to rep all the old timers as it were. Ya got some.
Old Aug 22, 2008 | 09:41 PM
deereman4020's Avatar
deereman4020
and the Electronic Shift On the Fly for 4X4 trucks
Old Aug 22, 2008 | 09:54 PM
greagin's Avatar
greagin
when the ac is on does the pump hold the door open or only open and close it? it honestly seems to happen mpst when the brake is applied. but its coming from the passenger side and it literally a muffled but very audible womp womp womp womp womp until the brake is released and i apply the throttle. could it be something in the power steering pump or hydraulics? it sure does sound like air though and the ps pump is on the driver side. very perplexing and annoying. does not seem to affect performance. i thought it may be a leak in the vacuum reservoir or even a leaky pump. also seems more noticeable when the wheels are turned all the way to the right or left. may just be coincidence though as i hear it mostly in slow turns like pulling into the driveway or parking or something
Old Aug 22, 2008 | 09:58 PM
empiretc's Avatar
empiretc
ah, yes. good catch. ESOF as well.
Old Aug 22, 2008 | 10:01 PM
empiretc's Avatar
empiretc
Many, between the spreading them around and the 24hr. limit, giving Reps where they are due is getting tough.
I'll catch up to you and deereman4020 asaic.
Old Aug 22, 2008 | 10:06 PM
empiretc's Avatar
empiretc
check the pulley and shaft on the powersteering pump for play. also check the idler pulley and belt for wear.
Old Aug 22, 2008 | 10:09 PM
superduty4x4's Avatar
superduty4x4
My old 460 made a weird noise similar to what you are describing but it never gave me any problems... could it just be that you're more in-tune with your truck than in the past so you are noticing it now???
Old Aug 22, 2008 | 10:24 PM
greagin's Avatar
greagin
i have been noticing it for a while now. i just changed the entire belt tensioner assembly, brake master cyinder, fuel pump, fuel filter, and installed in tank mods this past weekend. not to mentioned dropped my fuel tank and cleaned out. some ******* put water and sand in my fuel over last weekend. i only pray i catch who did it. actually they did me a favor as i have had the in tank mods in my garage for 6 months now but just been too lazy to drop the tank and install them. anyway, i will listen for it closely tomorrow as now that i think about it the belt tensioner assy could have been weak. i changed it because a pulley was squealing and all napa had in stock was the entire assy. how convenient.
JHoffman93
Mar 19, 2013 09:57 AM
Big Sky
Oct 29, 2012 05:30 PM
Mikey Oldaker
Feb 27, 2012 04:41 PM
Rollbar
1997 - 2003 F150
Apr 2, 2011 08:48 PM
7.3bo-ti-etr
Jan 29, 2011 09:40 PM
