Van 5.8 into F150
Old Aug 22, 2008 | 10:59 AM
currituckF150's Avatar
currituckF150
Van 5.8 into F150
It appears that the pinouts & computers are the same for E & F series, Is there any thing else that needs to be comsidered when doing this swap?
Old Aug 22, 2008 | 11:16 AM
Conanski's Avatar
Conanski
What year is the motor?
What tranny does your truck have?
Motors for both E and F series are all the same, so there won't be much stopping you from dropping this right in. The 5.8 is balanced different than the 5.0 so it requires a different flywheel/flexplate, and these are tranny specific. Ford moved the TFI module from the distributor to the fender in '91 or '92, so if the replacement motor is from the other side of this split from your truck you will need a different distributor.
Old Aug 22, 2008 | 11:49 AM
currituckF150
Paul, I'm waitning on the guy who has the motor to tell me the year but the motor & computer came out of a van w/ a E4OD. My truck also has an E4OD. So, the only difference is the flexplate, balancer & ignition module location? Sweet!
Mar 14, 2022 01:24 PM
chris69
17
Dec 16, 2003 10:30 AM
billman
Jan 16, 2003 04:30 PM
2004 - 2008 F150
61
Jan 15, 2003 03:03 PM
michaelskerrett
Jan 13, 2003 09:51 PM
