Has anyone replaced the front-end parts mentioned in this TSB ??
Service Bulletin Number: 97-3-10
Bulletin Sequence Number: 10
Date of Bulletin: 9702
NHTSA Item Number: SB051669
Make: FORD TRUCK
Model: F150
Year: 1990
Component: SUSPENSION:I-BEAM:SOLID:FRONT HANGER:BRACKET
Summary: NOISE- "POPPING/CREAKING"- FRONT FRAME OR SUSPENSION BRACKETS- FRAME- "POPPING/CREAKING"-FASTENER REPLACEMENT. *JD
How can I get a copy of this bulletin?
Will my local dealer give me this information?
Thanks in advance for your help.
Mike Salomone aka mickeys@sedona.net
My truck was making strange popping sounds...thought it was a bad part in the steering, but ended up finding that one of the bolts that holds the brackets had sheared off...Didn't know there was a TSB on it...
