Liquid Electrical Tape
Old 08-21-2001, 03:47 PM
CrmScntst's Avatar
CrmScntst
CrmScntst is offline
I saw some liquid electrical tape at CAP, it appears to be sorta like rubbewr cement or something, has any one ever used this for their wiring? Is it better or worse than shrink tubing?
Thanks,
Chuck
Old 08-21-2001, 04:29 PM
sparky's Avatar
sparky
sparky is offline
Thanks,
Chuck
Depends on what you are using it for. From my experiences with it, it is excellant to seal rear of connectors and switches. However for wire repairs it is a little messy and the surface dries fairly quickly making it somewhat hard to spread out to an even coat. It also "wicks" into breaks in the wire, and coats individual wire strands reducing conductivity paths.
Hope this helps.
Sparky
Old 08-21-2001, 06:18 PM
CrmScntst's Avatar
CrmScntst
that was my concern, they show it on wire to wire connection, but looks sloppy, plus I was concerned with pathway interference,
thanks for the info dude.
Old 09-08-2001, 09:43 PM
Boltgunner's Avatar
Boltgunner
Boltgunner is offline
This stuff seems great for waterproofing. I have an electrically-powered swimming pool cleaner - it has two 24V motors within it to make it crawl along the bottom as well as to pump water through an on-board filter. Had one of the wires break internally within the jacketed cable that runs down into the water. For some reason, the wire wouldn't solder, so I used a splice crimp and coated the joint with the liquid electrical tape. Yes, it can get messy, but I brushed on several coats, allowing it to cure between applications (a few minutes), and that sucker has been in my pool and goobling up crud off the bottom without any trouble. Very neat stuff! Just brush it on lightly, so it doesn't drool off the wiring. Several coats later, don't look back.
Boltgunner
76 F-150 RANGER Extended Cab w/ 8' Bed, turn radius of a Super Tanker, uses same amount of gas...
Old 09-09-2001, 02:11 AM
77_f250_460's Avatar
77_f250_460
77_f250_460 is offline
diesel_dan
10-13-2016 06:09 AM
Cruiseomatic
Electrical Systems/Wiring
13
09-29-2016 11:27 AM
dustyroad
06-18-2016 11:55 AM
warthog5
2009 - 2014 F150
15
08-22-2012 06:53 PM
Jrock909
General Automotive Discussion
08-02-2006 02:55 PM
Quick Reply: Liquid Electrical Tape
