78 F150 Tranny problems.
Old Aug 21, 2008 | 08:25 PM
mrlightrail's Avatar
mrlightrail
Made a mistake of adding 1/2 quart of Mercon to my C6 transmission, and now am experiencing shifting problems. In Drive, vehicle appears to take off in second gear, but will shift to third. By manually shifting, I can get the truck to go into first.
I'm planning on replacing the vacuum modulator and changing the fluid and filter. I need help with information on how to make sure ALL fluid is out of the transmission/how to get all of the fluid out of the tranny. I'm also replacing the vacuum hose from the engine to the modulator to cover all my bases.
The truck has over 160,000 on it, so it's probably due for a transmission flush.
Old Aug 22, 2008 | 07:40 AM
classicranger's Avatar
classicranger
The torque converter has a drain plug, you will have to have some help to find it, get someone to turn engine over with wrench at crank shaft untill you see drain plug. The mercon shouldn't have mattered. What year trans you workin on? When i changed mine i filled it with mercon, with torque converter drained it took 11 quarts.
Old Aug 22, 2008 | 08:13 AM
duste's Avatar
duste
The mercon should not have caused your trouble. Is it possible that when you were adding fliud you knocked the vacuum hose off the intake that goes to the Modulator valve, Because it sounds like it's a vacuum problem or a bad mod. valve.
Old Aug 22, 2008 | 02:02 PM
mrlightrail
I'm also leaning towards a vacuum problem, as I remembered just before the issues began, I had a blowout on my LF tire, and limped the truck home to replace it, took a real beating, even at 5mph. Something may have gotten knocked loose during the drive.
Old Aug 22, 2008 | 02:06 PM
mrlightrail
I am assuming that it is the original transmission which would be a 78. I might have to pass on draining the torque converter, though. Transmission fluid is running about 4 dollars a quart here.
Old Aug 22, 2008 | 11:35 PM
Tha_Stepside's Avatar
Tha_Stepside
Lol, no offense guys but you yankees sound funny saying "quart" an all....It's a litre eh!!
Old Aug 22, 2008 | 11:46 PM
mrlightrail
Ok, done all the work, but still having problems, but now, the truck does not want to shift up from first. I'm thinking the new modulator needs to be adjusted. Hoping it works.
Old Aug 22, 2008 | 11:48 PM
mrlightrail
Wink
Here in these parts, we buy gas by the gallon, drink by the fifth,and buy oil by the quart.
Old Aug 23, 2008 | 12:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Uh...Ford went to MERCON beginning in 1977 for use in C6's and C4's.
Type F was used in prior years.
The 1973/79 Ford Light Truck Parts Catalog in the Motor Oil & Lubricants section sez:
XT-2-QDX Automatic Transmission Fluid "MERCON" / 1977 and later C4, C6.
Old Aug 23, 2008 | 09:10 AM
19774X4's Avatar
19774X4
Yep! Sounds like a modulator adjustment. Last month I gassed it really hard and blew my vacuum line right off the valve. It just wouldn't shift out of first.
86Bronco6
1978 - 1996 Big Bronco
Jun 11, 2012 06:29 PM
T3hn1cksta
Feb 18, 2011 09:02 AM
Greywolf
Nov 15, 2002 09:23 PM
