What else could it be?
Old Aug 21, 2008 | 07:04 PM
pavco281's Avatar
pavco281
Hey guys. My 78 f150 w/351M and holley 4bbl has a rough spot when I'm on the gas after the engine is warmed up. In the past 2,500 miles I've done carb rebuild, new plugs, wires, cap, rotor, fuel filter and set the timing, fuel mix and float level.
It was running great for a long time (majority of the 2,500 miles) until about two weeks ago. Now it has this rough spot, almost a hesitation/stumble. Doesn't seem as bad when cold or at higher rpms.
Tried my spare ignition module today and rechecked the float level and tried a few different timing settings...now I'm back to 14 degrees btdc. Engine still acts the same.
I've been searching the site for a while now, all the suggestions to cure hesitation seem to be the things I've tried.
I guess power valve is next, unless someone here has another suggestion.
Thanks
Old Aug 21, 2008 | 07:16 PM
JBradley500's Avatar
JBradley500
i was kind of thinking power valve. its so cheap and easy to change, you might as well do it. it probably will cost you 5 bucks and take less than 5 minutes.
Old Aug 21, 2008 | 07:23 PM
fastfarmer's Avatar
fastfarmer
Have you removed the fuel bowl and looked at the jets? I've seen several times when a small piece of debris in one of the main jets caused somthing like your problem.
Old Aug 21, 2008 | 07:27 PM
Big billy C's Avatar
Big billy C
check out the dist. " just in case " and see if it has walked around on you. just see if the bolt is tight thats all i can think of .
Old Aug 21, 2008 | 07:58 PM
pavco281's Avatar
pavco281
Thanks guys.
Yeah, I'll probably throw in a new power valve tomorrow first thing, eliminate that possibility.
I have checked the carb for obstructions.
The dizzy is definitely tightened down at 14 degrees btdc.
I've always run 93 octane...could it be this higher alcohol content gas?
Should I tune it differently from the stock settings?
Maybe I'll pull the spark plugs again tomorrow too.
Old Aug 21, 2008 | 09:35 PM
montana_highboy's Avatar
montana_highboy
Check the advance mechanisims in your distributer, both mechanical and vacuum for smooth operation.
Old Aug 22, 2008 | 04:24 PM
Dr. Dirt's Avatar
Dr. Dirt
I'd say distributor.
Old Aug 22, 2008 | 05:19 PM
mark a.'s Avatar
mark a.
Put a fuel psi gage on it and see what you got.
Old Aug 23, 2008 | 09:37 AM
pavco281's Avatar
pavco281
Thanks for the info guys.
I'll check the dizzy advances today after work, hopefully. Then look down the carb if the advances are working ok.
Old Aug 27, 2008 | 03:57 PM
pavco281's Avatar
pavco281
Problem solved...dizzy...thanks for the help guys!!!
It was the dizzy. Pulled it and it had a catch while spinning it, I guess the bushing was shot. So, got the new dizzy in today and the truck is running great. Good acceleration bottom to top, nice idle and no hesitation or flat spots. Dad said I even smoked the tires pulling away from the garage on the fist round the block after setting the timing.
Thanks for the help guys.
