Emergency Flashers - '95 Explorer
Old Nov 7, 2001 | 03:36 PM
LugnutLouie's Avatar
LugnutLouie
Anybody out there able to give some insight in what I should be looking for as a cause for no activity from my flashers when I push the button. I have checked the fuse and it looks great. I am not even sure if they have ever worked. I've never used them until I was showing the daughter how to turn them on.
Thanks
Old Nov 7, 2001 | 08:31 PM
sparky's Avatar
sparky
Somewhere in that "new modern technological machine" , all the trucks I have owned are from the early,early 80's and before, there must be a flasher unit.
It is usually a cylindrical looking 2 pronged plugin type, often close to the steering column or fusebox behind the dash in a very hard to get at area This unit is what causes the flashers to flash. Same kind is often used for the turn signals so if you find both in the truck you can swap them for troubleshooting.
In my experiences if it isnt the fuse it is this unit that is dead.
Sparky
Old Nov 7, 2001 | 08:53 PM
LugnutLouie
Thanks Sparky.
That is my little bit of experience also.. Odd thing is I didn't see, in my decent search, any unit except the one that I felt clicking as the turn signal, I had turned on to make sure it was it, flashed.
Never saw any other. that is what stumped me on this one. Left wondering if these fine minds at Ford have pulled a fast one on us old time under dash men.
Thanks again!
Old Nov 8, 2001 | 08:09 PM
Franklin2's Avatar
Franklin2
