Truck Wont Stop
Old Nov 8, 2001 | 04:58 AM
CowboyMjoh's Avatar
CowboyMjoh
Truck Wont Stop
Hello. I have an 83 F-250 4X4 (351w). When I turn the key to the off position, it wont shut off. The lock cylinder is fine, the igniton switch is good. I have been working on this one for weeks now. Is it that the coil is not being grounded through the switch? The circut is obviously not being opened somewere, and I cant find were. What else could it be, has anyone else had this happen to them? Any help would be greatly appreicated.
Old Nov 8, 2001 | 08:09 PM
Franklin2's Avatar
Franklin2
Truck Wont Stop
See if you are getting voltage on the brown-pink wire coming out of the ignition switch. This is supposed to have voltage during start only. Of course the main wire is the red/lightgreen wire that goes from the switch to the coil. The problem has to be there somewhere, unless someone has tied something else on the coil wire that's not supposed to be there.
Old Nov 9, 2001 | 03:28 AM
charlez's Avatar
charlez
Truck Wont Stop
