Shackles F250
They are pretty stout and fit well
Welcome To SKY Manufacturing! Suzuki Samurai Toyota Parts
Thats all I can tell you from my experience
I really didnt want to go much bigger on hangers and shackles than 2''
This is the magic heigth where the front driveshaft starts to get a little short, if you are still using a front sway bar, and will continue to do so, the sway bar links will be too short.
The trac bar is also going to be too short, and a new bracket will be required, as will the angle on the drag link. A drop pitman arm will be needed to keep steering at a reasonable angle, and to keep the trac bar at the same angle.
While you can re-locate the brake lines, and ESOF hoses (if equiped), these too start to get a little on the short side.
There is a little more to this than just a hanger and shackle.
