big block power
Old Aug 18, 2008 | 08:04 AM
fjh321321's Avatar
fjh321321
Unhappy big block power
iam new to the bbf execpt to 460 just wondering what the defference between the 390 429 n 460 will they all enterchange with each other will the 390 take 429 or 460 heads etc. trying to build a 429 with out the 460 if possible just a stock 429 going in a 1995 mustang cant find a good truck or good motor 2 start with either all on ebay want to much for shipping to buy a good 429 block is the 429 and 460 pistions the same size in diameter or around please email me with any answers at mg20sm@yahoo.com thanks very much
Old Aug 18, 2008 | 09:00 AM
JesterPgh's Avatar
JesterPgh
The 390 won't interchange with the 429 and 460. You can make a 460 into a 429, but externally, there's no difference, so why not just keep the 31 extra cubic inches?
Old Aug 20, 2008 | 08:22 AM
fjh321321's Avatar
fjh321321
hey jesterpgh will the pistons cam rods heads every thing on the inside of the block from a 429 fit in the 460 block email me please n thank u
Old Aug 21, 2008 | 10:55 AM
mcdonaldm's Avatar
mcdonaldm
the two things that are different from a 429 and 460 is the crank and pistons. the rods, heads, valvetrain, block, etc are identical and interchangeable between the two.
the 429 piston has a different pin location than the 460 psiton due to the longer stroke of the 460. so to make a 429 into a 460 you have to replace the crank and pistons. pretty simple way to get an extra 31 cu in.
rgds
Mike
Old Aug 28, 2008 | 05:49 PM
fjh321321's Avatar
fjh321321
Talking mcdouldm
hey mcdouldm iam trying to turn the 460 into a 429 sorry for the mis understanding could you tell me what i need to do to get the 460 down to a 429 just want a 429 that is why i dont keep the 31 extra cubes thanks email me please mg2osm@yahoo.com
Old Aug 28, 2008 | 07:09 PM
Bear 45/70's Avatar
Bear 45/70
Same deal, change to the shorter stroke 429 crank and use 429 piston.
Old Aug 29, 2008 | 02:20 PM
fjh321321's Avatar
fjh321321
Talking big block power
thanks bear 45/70 any thing else you can think of that would give me problems going down to the 429
Old Aug 29, 2008 | 02:35 PM
Bear 45/70's Avatar
Bear 45/70
You need to make sure you have a 429 flywheel or flexplate as the later 460s (1972 on on) were externally balanced and the 429 were not.
77 2wd
Ford Truck Parts for Sale
Dec 4, 2012 09:09 PM
429holeshot
General Automotive Discussion
Oct 27, 2008 10:05 AM
danwalker20
19
Apr 30, 2007 08:19 AM
boss429
29
Nov 27, 2003 09:26 AM
hdbd1
May 26, 2002 07:17 AM
