Suspension swap?
Old Aug 17, 2008 | 06:36 PM
motopsyko32's Avatar
motopsyko32
Suspension swap?
Will a 94-96 Lightning suspension fit a 2wd 94 F150 XLT?
Old Aug 17, 2008 | 08:12 PM
nytling92's Avatar
nytling92
What are you after bu doing this?
Old Aug 17, 2008 | 08:30 PM
fastback69's Avatar
fastback69
In short, yes it will. I got coils from Ford for ~$36, leafs from Eaton Detroit Spring (expensive but not much more than ordering from FoMoCo), swaybars from SwayBar.com Your source for classic Mustang sway bars, urethane bushings from a local shop, and Bilstein shocks. I still need urethane swaybar end link bushings. The ride is quite harsh with the eaton springs/Bilstein shock combo. I don't mind though. I autocross my truck with this combo and haven't come in last yet. I get compliments from national-level drivers, and riders always... ALWAYS end up having a blast around the track. If you like curvy roads, taking on/off ramps at 2x the posted, and don't mind a bit of a rough ride; I say do it. Might want to try Tokico shocks instead of Bilsteins, though. It's "log truck" rough going over rough pavement.
Don't forget to find a longer pitman arm off of a LWB truck or a 4x4 for a quicker steering ratio.
Coil spring p/n: F3TZ 5310 A
Leaf p/n: F3TZ 5560 B
Spring code: P4J
Bilsteins: Frt AK1289 R AK1290
Old Aug 18, 2008 | 08:33 AM
ma94xlt's Avatar
ma94xlt
Recently did this swap to my 94xlt. Everything bolted right up. I swapped, front coil springs, and spring perches with the sway bar mounting point. Also swapped in rear springs, sway bar and 8.8 from an 93 lightning. The sway bars aren't a direct bolt in without a couple parts. On the front is the spring perches, and the rear is a bracket for each side, where sway bar mounts to frame.
Old Aug 18, 2008 | 07:03 PM
motopsyko32
sweet... I just wanted the aggressive stance the lightning has
Old Aug 18, 2008 | 08:11 PM
ma94xlt's Avatar
ma94xlt
Springs are pretty much direct swap. Guy was selling a set of front springs on the lightning site for $80, www.nlco.net
Old Aug 20, 2008 | 10:15 AM
motopsyko32
Thanks.......
Bigal700
Dec 4, 2015 01:48 PM
He-Man94F350
Oct 11, 2013 07:43 PM
smajr85
Jan 7, 2013 12:26 PM
crestfallinman
15
Jan 3, 2008 08:02 AM
dziner92821
1983 - 2012 Ranger & B-Series
Jan 23, 2004 03:21 PM
