oil pan woes
Old Aug 8, 2008 | 10:46 AM
codyman1200's Avatar
codyman1200
oil pan woes
I've recently acquired a 1991 F150. 2WD, 4.9L
Oil pan has a hole in it due to rust. Is it possible to swap the pan without pulling the motor?
Thanks
Cody
Old Aug 8, 2008 | 10:51 AM
andym's Avatar
andym
Yes. You will have to remove the upper intake (so it will clear the firewall) and unbolt it from the mounts. Then you have to jack it up by the crank pulley far enough to slide the pan out from underneath. Replace the pump and pickup screen while you have it apart.
Old Aug 8, 2008 | 11:01 AM
quicklook2's Avatar
quicklook2
andym, on a v8 you have to, but not on a six.
put truck on ramps, unbolt fan shroud, lay on fan, unbolt battery, unbolt both motor mounts, with block of wood jack up the motor as far as you can, put wood blocks between mounts and frame but not in the way, unbolt trans mount at trans, remove oil, pan screen, pump, lay these in pan, then try to remove pan, if you can't use floor jack to jack up trans. as far as you can.
don't get high volume pump, do replace pump, pick up screen and use one piece felpro gasket.
post if you have problem.
i have done these a few times.
welcome to fte.
good luck.
Old Aug 8, 2008 | 11:15 AM
andym's Avatar
andym
Huh. Ok, coulda sworn.
Old Aug 8, 2008 | 01:00 PM
Ford Breakdown's Avatar
Ford Breakdown
Did mine on a '95 I6 just unbolted the motor mounts and lifted the engine a bit with a crane and was able to slide pan out. Unfortunately, it's time for me to do it again 5 years later. Do use the wood blocks too, no point losing fingers.
Old Aug 11, 2008 | 01:25 PM
codyman1200
Thanks for the input. I'll give it a try this weekend.
Old Aug 12, 2008 | 07:43 AM
alz's Avatar
alz
Luckily on the I6 you don't have to worry about that darn y-pipe like the V8s.
Old Aug 15, 2008 | 09:16 AM
codyman1200
Ok, I was able to complete the pan swap last night, but have discovered a slight problem. When I finished the job and was cleaning up, under the cardboard I was laying on I found the steel rails for the oil pan bolts. They sit on the outside of the pan for reinforcement - presumably to make the gasket seal better. Has anyone successfully installed an oil pan without these? Should I expect it to leak? Is it worth putting them back on???
Thanks
Cody
Old Aug 15, 2008 | 09:53 AM
quicklook2's Avatar
quicklook2
i would put them back on.
loosen all the bolts some, remove the ones you have to, torque to specs.
no sense cutting corners now.
glad you got her out and back in.
good job so far.
Old Aug 20, 2008 | 12:12 PM
codyman1200
Since the job was complete before i noticed the reinforcing rails were not on, I decided to try my luck and see if it would leak. Sure enough, it does. Looks like I will be putting them on for sure now. Thanks for the input.
Cody
bvieages
Aug 30, 2014 10:46 AM
jrichardson42
Feb 1, 2008 03:41 PM
maximumhorsepower
Dec 27, 2003 10:48 AM
horsepuller
Dec 15, 2001 09:11 PM
