wont rev fast
Old Aug 17, 2008 | 03:07 PM
old76er's Avatar
old76er
wont rev fast
I have a 1976 f100 with a 360, man. trans.4x4 I have replaced all fuel lines and pump, the distributer, the carb has been rebuilt, and timed over and over, replaced all vacuum lines( and hooked them where they were), changed plugs and wires, changed vacuum advance, and made sure I was getting good vacuum from the carb,when the engine is running it idles fine and if you depress the gas pedal slow it will rev, but if you try to rev fast you can hear a sucking sound from the carb and it almost dies. anybody got any more ideas,
Old Aug 17, 2008 | 04:10 PM
Dr. Dirt's Avatar
Dr. Dirt
well when you rev my truck you can hear a sucking sound from the carb, but it doesn't die.
sorry I can't help you.
welcome to FTE!
Old Aug 17, 2008 | 04:52 PM
4x4 Bart's Avatar
4x4 Bart
Does it want to backfire through the carb at wide open throttle.
If it does its most likely starving for fuel.
Old Aug 17, 2008 | 05:13 PM
80F100man's Avatar
80F100man
Sounds like a vaccuum leak possibility , mine has a sucking sound too, but I believe mine is really a big glug of fuel being consumed......lol
Old Aug 17, 2008 | 09:11 PM
chuck101st's Avatar
chuck101st
Alot of time if it idles but you can't accelerate, it is the accelerator pump in the carb..
Old Aug 18, 2008 | 04:17 PM
65f100_352's Avatar
65f100_352
What kind of carb do you have?
Old Aug 20, 2008 | 10:38 AM
old76er's Avatar
old76er
I have a Motorcraft 2 bbl, the original carb, and if I get it to a high rev speed it will try to backfire through the carb. I know I don't have a vacuum leak, last night I took a propane torch with the flame out and gas on and went around all the vacuum hoses. Tonight I'm going to start adjusting the fuel air mix with more fuel
Old Aug 20, 2008 | 11:28 AM
hairyboxnoogle's Avatar
hairyboxnoogle
As said above, i would suspect the accelerator pump. when the truck is off climb up there and manually work the trottle and whatch if the pump is squirting fuel in... if not, then theres your problem. Also is it a backfire? or a lean pop? A lean pop is pretty self explanitory, the engine is starving for fuel and it pops. If thats not it.. id check valve timing.
Old Aug 20, 2008 | 09:25 PM
fmc400's Avatar
fmc400
MSEE
Sounds like an accelerator pump issue. Hairyboxnoogle is pretty much right on target. With the truck off, take the air cleaner off the motor and look down the throat of the carb. Pull the throttle back, and you should see two good streams of gas shoot onto the venturis in the carburetor. If not, your accelerator pump could have a ruptured diaphragm or a linkage problem.
Check your timing as well. As for the sucking sound, that's somewhat normal if you stomp on the gas, but spray for vacuum leaks to check. My money is on the accelerator pump or float height.
Old Aug 21, 2008 | 09:05 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
I know that sucking sound hes talking about. Its not the typical healthy sound. Its that sound you hear when the carb doesnt have enough fuel. Check your float level, filter, look for kinks in the fuel line, maybe even the pickup screen in the gas tank or as noted maybe its the accelerator pump. At least you know its a fuel delivery problem.
Old Aug 23, 2008 | 08:12 AM
old76er's Avatar
old76er
well I checked the float level with the little ruler that comes with the rebuild kit and the float was to high, I changed it to the right height 31/64" , i went around the vacuum hoses with the propane again, Then I ajusted the fuel/air mix a little at a time all the way to 5 turns each, and timed it again, still there is no change, there are two steady streams of gas when you hit the gas so its getting plenty
Bugzturbo
28
Jun 28, 2014 02:32 AM
mac_attic
Jul 28, 2012 08:11 AM
gfw1985
May 27, 2008 08:57 AM
enskpo
Feb 5, 2006 10:27 PM
jvicars4
Jun 17, 2003 09:04 PM
