Guages
Old Aug 17, 2008 | 11:36 AM
pctahlequah's Avatar
pctahlequah
Guages
Hello, all. I have an all original 62 f100: 352/4spd/9" rear. Does anyone know where I can get the guages rebuilt? It has a single round module that holds everything.
Old Aug 17, 2008 | 01:03 PM
gangstakr's Avatar
gangstakr
Check out this ebay item # 170249421319
having your's rebuilt might be costly, a lot of these are available on evil bay. Depends what you want to spend. For instants, ebay item # 370052335451
Your money.
Or take an OHM meter to your local pull aparts, and find one that works. Like I said it's all about money.
Old Aug 17, 2008 | 03:30 PM
ddavidv's Avatar
ddavidv
Uhm, 352 not offered in the trucks until 1965. Did you mean 292?
Old Aug 17, 2008 | 08:54 PM
blloyd's Avatar
blloyd
ddavidv, was the 292 the largest V-8 put out in 1962 for the F-100 ??
Old Aug 17, 2008 | 09:47 PM
Sam_Fear's Avatar
Sam_Fear
Anyhoo, these gauges show up all the time on e-bay and often don't sell. What's wrong with your gauge cluster? you may just need a new gauge voltage regulator.
Old Aug 18, 2008 | 05:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/64 F100/350: the 292 2V was the only V8 offered.
B9MZ10804C .. ICVR (Instrument Cluster Voltage Regulator)
The ICVR is available from autoparts stores, but make SURE to take the old one with you.
1961/66 F100/350's use one type, 1961/66 F500/1100's use two types.
The parts catalogs used by autoparts stores may not show any difference.
Old Aug 18, 2008 | 07:04 AM
ddavidv's Avatar
ddavidv
There was only one V-8 option 61-64, the 292 Y-block. It's easy to spot as it's got two centered valve cover nuts and the motor mount is at the front. It also will have the goofy front crossover exhaust pipe if it's original.
65-66 was upgraded to the 352 FE block, a giant cast iron monstrosity with motor mounts on the sides and valve cover bolts around the perimeter.
Anything else in there would have been swapped in.
Old Aug 18, 2008 | 07:32 PM
pctahlequah
Exclamation
Ok...so the 292 would have a goofy crossover pipe? I thought the 352 had a crossover. This is my first old Ford truck, I usually mess with Mustangs.
Here is everything off the Data plate in the glove box:
F10CR312277
WB: 122 Color: J Model f100 Trans: F Axle: 11
GVW: 5000 H.P.: 135 @ 3800 D.S.O. : 71
From what I've read in these forums, I think I got screwed when I bought this. But it runs and drives and has a lot of potential, so maybe I didn't.
Old Aug 18, 2008 | 07:40 PM
pctahlequah
Thumbs up
Your money.
Thanks, fo rthe input, Robert. I think I will try the salvage first. Only problem there is that most of the yards around me have crushed all the good stuff.
Old Aug 18, 2008 | 09:16 PM
gangstakr's Avatar
gangstakr
What exactly are you looking for?
Old Aug 18, 2008 | 09:41 PM
billy12360's Avatar
billy12360
F10CR312277
IF and only if the first few didgts and letters of the vin numbers are the same between 63 and 62... you have a 292 y-block
Old Aug 19, 2008 | 11:51 AM
NumberDummy
F10CR312277
F10 = F100 2WD
C = 292 2V
R = San Jose Assembly Plant
312277 = 1962 Assembled July 1962
122" Wheelbase
J = Rangoon Red
F100 = F100 2WD 5,000 lbs. GVWR
F = Warner T-98 4 Speed
11 = Ford 9" / 3,70-1 / non Limited Slip / 3300 lb. Rear Axle capacity
5,000 lbs. Gross Vehicle Weight Rating
135 HP @ 3800 RPM
71 = Los Angeles Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
Why do you need the gauges rebuilt? Is it because the paint on the needles has faded?
Women's nail polish (yes, that's what I said), is what restoration shops usually use. New gauges are not that tough to find.
Old Aug 19, 2008 | 07:51 PM
gangstakr's Avatar
gangstakr
Hey Bill what color nail polish? I've got gauges that could use a touch up.
Old Aug 19, 2008 | 07:54 PM
gangstakr's Avatar
gangstakr
F10CR312277
What makes you think you got screwed?
Old Aug 19, 2008 | 08:35 PM
Sam_Fear's Avatar
Sam_Fear
To recap:
Why do you need your gauges rebuilt?
Why do you think you got screwed?
What color nail polish Bill?
And .... GOT ANY PICTURES? We all love more pics of Slicks!
