Trailer recepticle connector replacement
Old Aug 16, 2008 | 12:04 PM
expy37at's Avatar
expy37at
Our 2001 Expy with the 7 pin trailer recepticle has had the trailer plug retaining tab, on the spring-loaded flap, broken off.
Now the plug can fall out of the bumper connector.
Ford is telling me that I have to buy the whole assembly, including the pigtail.
I've taken the recepticle off the mtg bracket and found the pigtail is removable from the 7 pin connector so the 7 pin connector is all I want to purchase.
I.e. I don't want to buy another pigtail, just the final connector that attaches to the bumper/hitch with 4 screws.
Anyone look into this before and have info?
Old Aug 16, 2008 | 02:31 PM
MisterCMK's Avatar
MisterCMK
Ours also broke. Ford charged me something around $90 for the connector and IIRC it does come with the pigtail that plugs into a connector on the frame. They have been on backorder since May though.
Old Aug 16, 2008 | 02:58 PM
cbradford's Avatar
cbradford
I would check with Etrailer.com as I purchased the 7 pin connector for my 97 that had only a 4 pin.
Old Aug 16, 2008 | 04:50 PM
notgmc's Avatar
notgmc
Most trailer and rv shops will sell you just the 7 pin head. Good luck.
Old Aug 16, 2008 | 04:52 PM
Eddie Hudson's Avatar
Eddie Hudson
Try NAPA, Pep Boys, Auto Zone etc. Most of the connectors are made by Pollak, which are available almost anywhere. Bring your old one to match up.
Old Aug 18, 2008 | 12:38 PM
saberworks's Avatar
saberworks
If no luck at auto parts store, try an rv store or boat shop, a lot of them have a lot of trailering accessories.
Old Sep 5, 2008 | 08:25 AM
gcmay's Avatar
gcmay
I had same problem 1999 Expy, went to the dealer in Logan, UT, parts man walked to the bins and brought out just the socket for me. No pigtail! Ford part.
Old Sep 6, 2008 | 07:32 AM
lakesidebluexpy's Avatar
lakesidebluexpy
and if you really get stuck, find a donar in the local wreck yard!
lakeside
Old Sep 6, 2008 | 09:32 AM
Oldtrucknut7077's Avatar
Oldtrucknut7077
You can always try walmart. That is where I got a replacement plug for my Expy. The wiring should plug right into the existing wiring. I had to attach the blue wire (brake power) another wire underneath. If you need further help, let me know and I can check later exactly what wire I tapped into (its pouring down rain at this present time). Good luck,
Scott
Old Sep 6, 2008 | 05:32 PM
2002 F350V10's Avatar
2002 F350V10
ebay, the 08 superduty plug is much nicer and wiring is plug and play. plus you have both the 7 pin and 4 pin with a nicer spring loaded flap. Guy in Indiana is selling new take offs for $30.
varminthunter243
Feb 9, 2017 11:03 AM
NotURMailman
Dec 4, 2015 07:33 PM
bossgobbler
Oct 27, 2011 08:18 PM
captsteve67
All Things Towing
Jun 19, 2009 06:51 AM
