6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF delete w/out throwing codes?
Old Dec 16, 2008 | 11:46 PM
The Gambler's Avatar
The Gambler
mick1955, what is the console vault that you have posted on things you've done to your truck??
Old Dec 17, 2008 | 04:27 PM
mick1955's Avatar
mick1955
It's a safe that mounts in your console. You can get them with a key lock, or combination. Very well made... Here's the link:
https://www.consolevault.com/product...e&value01=Ford
Old Dec 17, 2008 | 04:37 PM
rmosso1's Avatar
rmosso1
Console Vault - Ford - F250/350 Super Duty
Now available, this unique Console Vault fits perfectly in the center fold down arm rest. The installation is fast with just four self-tapping screws. This modal includes all of the fine features you expect from Console Vault with a factory installed look.
Massive 12 Guage cold rolled plate steel, welded tab and notch seams.
Superior 3 point locking system resist prying.
Bank Vault style hinge latch pins.
Exclusive lock cam prevents entry if lock is drilled.
Easy 10 minute installation.
Secures to factory console bolts.
Perfectly balanced spring assisted door.
High security barrel lock and two keys.
I am looking at them. Had the above info handy. Good luck. If you buy one, please let us know.
Old Dec 17, 2008 | 04:44 PM
mick1955's Avatar
mick1955
I have one in both trucks. They did an excellent job when they made these.
I did install 2 extra bolts in the front of vault, just for added security...
Here's some pictures I took when I installed my first one. I did remove the console, but it is not required. I made some modifications to it.
mick1955-1955 - Photobucket - Video and Image Hosting
Old Dec 18, 2008 | 11:59 AM
The Gambler
Thanks guys I'm going to order one. Gambler
turbinefix
Jan 12, 2016 09:52 AM
baja370
Oct 21, 2015 09:14 AM
js139
Mar 1, 2015 09:35 AM
Dieseldummmy
Dec 8, 2014 09:47 AM
08 F450 6.4L Dually
32
Mar 3, 2014 03:51 PM
