Sponsored by: Real Truck
Help??????
Old Aug 15, 2008 | 04:39 PM
gvandyke's Avatar
gvandyke
Help??????
Does anybody know how to remove a factory ujoint from a 1 ton front axel? I am replacing my stub shafts. I have pictures if I could figure out how to paste them.
Old Aug 15, 2008 | 04:48 PM
highland61's Avatar
highland61
https://www.motorcraftservice.com/pu...20/S3OMAIN.HTM
Old Aug 15, 2008 | 05:00 PM
gvandyke's Avatar
gvandyke
This did not show me the axle u-joint.
Old Aug 15, 2008 | 08:52 PM
pstrokejoe's Avatar
pstrokejoe
Same as any U joint, lube her up good, remove C clips if they're there. Rest one side on the ears, so the u joint has an opening below it. Then, I use a socket that's just bigger than the diameter of the u joint cap, and drive the other side down, off the u joint. A hammer works OK, but a press works better.
Old Aug 16, 2008 | 08:03 AM
gvandyke's Avatar
gvandyke
Thanks to all
Thanks for all of the responeses. I am taking axel shafts to a parts store with a shop here in town and they said they would take them apart for me. The clip looks like it is part of the yoke. i was unable to get them out. The gaps overhang the opening and cannot by pounded thru.
I am installing a Solid Axle Spyntec Hub Conversion Kit on my truck.
Again, THANKS
Old Aug 16, 2008 | 08:26 AM
aldridgec's Avatar
aldridgec
Definitely take picutres of the process! Post em back and let us know how it goes!
Old Aug 16, 2008 | 08:43 AM
gvandyke's Avatar
gvandyke
I will do that. Anything I can do to cotribute to this AWSOME site.
