Sponsored by: Auxito
Can't shift into gear
Old Mar 4, 2001 | 10:53 PM
gigigoud's Avatar
gigigoud
Hi There!
I can't put my truck into gear,the shift lever won't move at all.
Please help me before i tear it appart.
Old Mar 4, 2001 | 11:51 PM
knuckles's Avatar
knuckles
Turn your key 1 notch from the lock position (but not to the "on" position). See if your shifter will move now. If it will, check your stop lamp switch and fuse.
Let us know what you find.
Old Mar 5, 2001 | 05:25 PM
gigigoud's Avatar
gigigoud
Thank-you, Your help worked.
The problem was a small wire that was cut on the switch.
I repaired it and eveything worked fine.
Thanks again.
Old Mar 8, 2001 | 01:23 PM
eyoung429's Avatar
eyoung429
I have the same problem. I replaced the number 7 minifuse, replaced both taillamps, and the brake switch....BUT STILL NO GO!!!! HELP!!!!
Old Mar 9, 2001 | 02:02 AM
knuckles's Avatar
knuckles
Well...after all that, do your STOP LAMPS work?
Old Mar 10, 2001 | 11:13 AM
eyoung429's Avatar
eyoung429
My trailer lights still work, ran pigtails down from stock taillights to trailer harness and now have brake lights
Old Mar 10, 2001 | 11:04 PM
knuckles's Avatar
knuckles
If your stop lamps work but you still can' shift from park, check the wiring between the shift interlock solenoid and the stop lamp switch. If the wiring is ok replace the shift interlock solenoid.
Old Mar 11, 2001 | 08:08 AM
hertac's Avatar
hertac
ColeT24
Sep 21, 2014 06:27 PM
SoFla64
Jun 30, 2014 12:49 PM
Burburan
Mar 28, 2014 02:29 PM
heathenwilliam
Dec 20, 2011 06:51 PM
jonjamky
May 21, 2003 07:56 PM
