Modular V10 (6.8l)
Egr
Old Aug 16, 2008 | 05:10 PM
Heavy_Metal's Avatar
Heavy_Metal
Egr
The truck in my sig has a cracked header (my fault), previously I welded an egr bung on the header to ensure the egr would operate. Here's my dilemma.
I ordered the exact headers I had before (ebay) but now I have the ability to turn the egr off with my diablo tuner. Would it be ok to remove the egr pipe completely and cap the valve?
Old Aug 17, 2008 | 11:44 AM
Heavy_Metal
Nobody has anything?
Old Aug 17, 2008 | 11:52 AM
Skoda's Avatar
Skoda
yes sir, if it is indeed disabled, if you take the valve off to clean up/ make some more room, make sure your vacume lines are corked.
Let me tell yea it looks alot cleaner with out all that egr crap in there
Old Aug 17, 2008 | 05:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Just plug it, remove the EGR and all associated crud, and tape up the electrical connector if there is one for the DPFE.
Remember to plug the intake side of it too...
Be aware that you might fail a visual inspection
Old Aug 17, 2008 | 05:56 PM
Heavy_Metal
I'm ok with visual, it's just a safety inspectionin VA so it's ok.
Old Aug 17, 2008 | 06:13 PM
krewat's Avatar
krewat
By the way, just so you know, the EGR can HELP fuel mileage at low-load (cruising) ... and help reduce pinging under light-to-moderate loads.
So whether it's a good idea to get rid of it, I don't know...
Old Aug 18, 2008 | 08:33 AM
Heavy_Metal
I'll keep that in mind. I'll let you know how it turns out either way.
