Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Buddy's 06 problems
Old Aug 17, 2008 | 10:28 AM
  #31
LaredoF350's Avatar
LaredoF350
Sheldon, to get this back on topic. All the plug in modules (Edge, Quadzilla,etc) do not have tha ability to alter transmission performance. They somehow just act 'in line' to intecept and modify parameters. They do have the nice feature of being adjustable on the fly.
The actual programmers that plug into the diagnostic port actually 'program' the truck and can adjust things like shift firmness thus reducing slip. They cant be adjusted on the fly. These were the only ones that could be used to make higher power and not wreck transmissions.
There are some guys running an Edge for the power and adjustability on the fly then using an SCT 'tranny only tune' to just add some transmission control to prevent damage and increase shift quality.
Old Aug 17, 2008 | 01:17 PM
  #32
preppypyro's Avatar
preppypyro
Hmm maybe I should tell my buddy to check into the tranny tuner. Didnt know you could get a seperate one.
He might go for that if it saves his tranny.
Old Aug 17, 2008 | 11:51 PM
  #33
Dustin1690's Avatar
Dustin1690
Well I hope if he does it saves it
Old Aug 18, 2008 | 06:28 AM
  #34
96sherm's Avatar
96sherm
if he's got some cash kicking around, i say he buy another tranny and sent it away to be build for abuse... might as well do it right and toughen the mechanical side of it instead of playing geek with more computer stuff...
Old Aug 18, 2008 | 12:51 PM
  #35
preppypyro's Avatar
preppypyro
I agree with ya somewhat Sherm. Tuning can do alot more then a guy thinks though.
Hes having a hard time swallowing the idea of getting a tranny built up on his expensive truck that "should"(his words) be able to handle the chip with the 7kish lbs that he tows around.
Im just gonna keep telling him all what I find out, and relay the info to him and help him that way the best I can.
Old Aug 18, 2008 | 05:07 PM
  #36
LaredoF350's Avatar
LaredoF350
There is no way it can tow 7000 pounds with a 150 horsepower increase and live - what does he expect?
My heavy tow program is around a 50 hp increase and I have a 100 hp one for light towing like a boat or snowmobiles. My 150 is for driving around empty only!
Old Aug 18, 2008 | 06:14 PM
  #37
preppypyro's Avatar
preppypyro
How much is a PSD supposed to be able to haul in stock form?
I think he thinks that his truck works like a semi, the more hp the better.
Old Aug 18, 2008 | 07:32 PM
  #38
96sherm's Avatar
96sherm
tuning can't strengthen the components inside the tranny... all it can do is play with computer controlled parameters. play with parameters and your hard parts will fail.
Old Aug 18, 2008 | 08:03 PM
  #39
preppypyro's Avatar
preppypyro
Well, not always the case.
Changing your shift points can sometimes cause less wear and tear, and heat.
Trust me man, they dont set up a truck in the stock form to be the strongest they can be.
Old Aug 18, 2008 | 08:54 PM
  #40
LaredoF350's Avatar
LaredoF350
Slightly firmer shifts result in less slip, thus less heat. In a fluid drive automatic transmission it isnt the hard parts that fail, its usually a heat factor.
Old Aug 18, 2008 | 09:10 PM
  #41
LaredoF350's Avatar
LaredoF350
I cant recall but its in the brochures for fifth wheel and bumper hitch trailers for each configuration combination - 2wd, 4wd, gas, diesel, crew/ext cab, long/short box, SRW/DRW, etc.
I think the Superchips website has their interpretation of approximately what each power level can safety tow - usually the highest level is a no-tow rating!
In stock form they tow not bad, in the 50 hp program its simply sweet - smoother shifting than stock with the superstrong tow/haul feature like the original 2003 calibration had, and the turbo braking is like a mini-jake! With the 100 hp while towing the boat or sleds it will easily leave a stock empty truck in the dust (or do I mean smoke?). The 150 hp levelis for playing only - its like an 8000# 4x4 crew cab Mustang!
Old Aug 18, 2008 | 10:50 PM
  #42
Digger6's Avatar
Digger6
Use the clutch. If you by a pick up and you know you are going to be doing a lot of towing with it Why mot get one with the big stick in the middle?
Old Aug 18, 2008 | 10:52 PM
  #43
Dustin1690's Avatar
Dustin1690
Well that might be his problem towing in 150hp increase might keep blowing out his tranny maybe he should try the other settings like Laredo mentioned
Old Aug 19, 2008 | 01:58 PM
  #44
preppypyro's Avatar
preppypyro
Digger i couldnt agree with you more. Did you know that the autos are rated to tow more though? (least they used to be)
After driving big rigs for a few years, ive come to learn that the more gears, the better. You dont have to use them all, all of the time, but they sure are nice to have when needed.
Old Aug 21, 2008 | 03:05 PM
  #45
Digger6's Avatar
Digger6
There is a reason why all winch tractors have manual trannys. The more wieght you tow the more options you need. A 300 six with a 4 speed will out pull a 351 with an auto.
