Normal EGT's for crusing?
Old Aug 13, 2008 | 01:13 PM
4doorsuper's Avatar
4doorsuper
Hey guys -and maybe a gal or two...
Anyone know what the normal operating egt's are for a stock 04 6.0L under normal load (just driving the truck on the highway) at say 60mph & 1500rpm's?
I had an egt gauge go bad on me -it wouldn't read over 400 degrees, prior to failure i would see about 7-800 degrees at the above speed parameters. I got a new gauge, the readings now are between 9-1200 degrees. I'm wondering what to expect, or suspect....
I know egt's depend on load and fuel delivery and such, just looking for ranges -if that exists..
Old Aug 13, 2008 | 01:33 PM
bismic's Avatar
bismic
I assume your gauge is "post turbo"?
Old Aug 13, 2008 | 02:30 PM
4doorsuper's Avatar
4doorsuper
oops, left out that important fact, the probe is installed in the exhaust manifold.
Old Aug 14, 2008 | 06:17 AM
sacu's Avatar
sacu
My 04 reads 600-800 @60ish cruising, 900-950 on bigger grades (3.73 gears w/295's).
My 05 reads 600-800 @60ish cruising, 950-1025 on bigger grades (4.10 gears w/235/80's) Hope this helps.
Old Aug 14, 2008 | 07:17 AM
4doorsuper's Avatar
4doorsuper
Thanks, this give me a sanity check of sorts. I'm running 37", honestly i cannot remember my gear ratio, but it's stock, i'm guessing 3.73. I'm beginning to think the original gauge i had was defective and the one i have now is accurate. Banks Engineering was no help in filling me in on what values i should see (resistance wise) at the terminals to determine if my problem was the gauge or the probe. I'm wondering how they quality check their stuff b4 it leaves the assemble line...
Old Aug 14, 2008 | 01:01 PM
3000 FPS's Avatar
3000 FPS
My 05 reads about the same as SACU posted for his. I use a stewart warner gauge in the exhaust manifold.
Old Aug 14, 2008 | 08:05 PM
sacu's Avatar
sacu
If you had or could borrow a thermal gun you could shut the manifold and compare it to the guage or an thermal stick/heat cayon might even work. It's not a calibration and you would only be able to do it at idle but it should give you an idea if the guage is close.
What your EGT's at idle? I run at 300 cold in park and 500 warm in gear at a stop light.
Old Aug 14, 2008 | 09:24 PM
Blaster7Romeo's Avatar
Blaster7Romeo
I am seeing the same numbers as SACU
