Lighted Trailer Hitch Cover
Old Aug 13, 2008 | 01:11 PM
psquare7575's Avatar
psquare7575
So I haven't really looked at the wiring in my truck, but I am at a loss as to how to wire this so it doesn't blink with the blinkers, as well as stay solid with the brake light.
I got one of these
As of now, I have no trailer hitch wiring at all.. can anyone help?
Old Aug 13, 2008 | 01:32 PM
dakonthemountain's Avatar
dakonthemountain
I assume you want it on when the lights are on? If so, can't you simply splice into the tail light wiring for the running lights on your truck? You could splice a matching plug (from Ford?...not sure) into the truck wiring to plug the hitch cover into or get another type of matching male/female plug connection. Just my own thoughts,... good luck!
Dak
Old Aug 13, 2008 | 01:56 PM
psquare7575
That I could handle.. but I wanted this to work as a 3rd brake light.
Old Aug 13, 2008 | 02:00 PM
NOCO77's Avatar
NOCO77
It's made to just plug into your trailer plug. But since you don't have one, just tie into your rear side marker lights. The flat-4 trailer wire plugs can be bought anywhere and are standardized in their wiring (color/function, etc.) There are just 4 circuits - left turn/brake, right turn/brake, running light, and ground. A circuit tester light will make short work of this project.
Edit: just saw your update. Don't tie into the side markers, lol... You might have to run a wire up to the brake light switch on your pedal to get it to work the way you want it.
Old Aug 13, 2008 | 02:16 PM
psquare7575
To make it worse, the trailer I'd use is a 7 pin.
Looks like I made another project.
I'm thinking of changing the end on this to a 7 pin.
Then get a 7 pin receiver that mounts to the truck.
Go from that to one of those plug in trailer/vehicle adapters (I need the extra pins because the trailer has brakes and backup lights.)
The million dollar question is, is there a plug in trailer adapter that has outputs for backup lights as well?
Old Aug 13, 2008 | 02:44 PM
harley dude's Avatar
harley dude
most auto parts will give you a seven pin with all the lights including back ups. also a hot wire to charge the battery on the trailer if you have one. there is also a 4 pin already wired in that your hitch plug should plug into, but you would have to check pins for the brake lights
carl2591
36
Jan 31, 2020 07:15 AM
nswilliams
Sep 21, 2016 04:00 PM
FourbyFour12
2009 - 2014 F150
Jan 21, 2013 12:16 PM
Mystic_Cobra
All Things Towing
Mar 28, 2012 12:06 PM
IslandBlueV10
All Things Towing
Mar 17, 2011 08:33 PM
