clutch chatter
Old Aug 13, 2008 | 09:41 AM
harley dude's Avatar
harley dude
clutch chatter
greetings: have a 76 short bed with 360 and should be a 3.8 rear'. just installed a np 435 along with a napa clutch kit, pressure plate,disc,bearing,etc. flywheel looked good. but i get excessive chatter in low and reverse. i expect some in the oldies bot not this much. any thoughts?
Old Aug 13, 2008 | 12:08 PM
Rebel Warrior's Avatar
Rebel Warrior
Smile
http://www.summitracing.com/streetandstrip/tech_content.asp?ID={AE711979-A6D0-4802-A262-500D9F59D71D}
Causes of Clutch Chatter or Shudder• Improper break-in procedure• Flywheel not properly resurfaced before installing a new clutch • Flywheel or clutch disc friction surface not parallel with the crank flange surface• Flywheel has severe hard spots or hot spots• Flywheel has an improper step or cup dimension• Defective pressure plate and/or disc• Disc has inadequate or no marcel (not enough cushion between friction facings)• Oil or grease contamination on clutch facings• Worn or damaged clutch linkage• Bent cover assembly and/or clutch disc• Damaged/excessively worn U-joints or CV joints• Misaligned U-joints • Excessive backlash in differential• Excessive driveline angle• Improper gear ratio versus tire diameter• Improperly tuned engine• Worn/damaged engine or transmission mounts• Bad leaf springs, bushings or mounts
Old Aug 13, 2008 | 02:46 PM
harley dude
thanks for the list.have already eliminated some and will check out the others
