2002 Escape XLS trailer wiring help needed
Old Mar 16, 2002 | 02:30 PM
dsa's Avatar
dsa
Hi all !
As subject says, I have a 2002 Escape XLS, Front Wheel Drive, 4Cyl., 5 speed man. transm. Don't have factory towing package (it's not even an option on XLS/4cyl/FWD. However, according to manual, I can tow up to 1000lbs and that's enough for my need (small trailer, small runs, etc.)
I already bought/installed Hidden-Hitch #90635.
Last week, visited my dealer and asked for trailer wiring. I was sold YL8Z-13A576-AA (Wiring kit with flat 4-wires) which I installed this morning, connecting it to harness hidden under back left panel in cargo area.
Now, The is no power to both flasher/brake wires. There is power though on parking lights.
I guess I'm missing a relay or converter somewhere. Could someone give me Ford part number and location for that possible "missing link" ?
Thanks in advance !
Denis
Old Mar 16, 2002 | 04:15 PM
Mil1ion's Avatar
Mil1ion
You don't need anything special except maybe a HD flasher.
Brown to Tail-lights
Yellow -Left signal
Green - Right Signal
4th terminal is Ground.
Nothing to it.
The brake lights /signal lights automatically wirk.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
[font color=blue]Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [font/]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 16, 2002 | 05:41 PM
dsa's Avatar
dsa
[updated:LAST EDITED ON 16-Mar-02 AT 06:43 PM (EST)]>You don't need anything special except maybe a HD flasher.
>Yellow -Left signal
>Nothing to it.
Not sure I understand your answer. Here is what I bought from my ford dealer:
http://pages.infinit.net/dsa/Pics/YL8Z-13A576-AA.jpg
Then, in my Escape, once side panel removed, There was that (white)connector (Other on right is for 12V power source):
http://pages.infinit.net/dsa/Pics/Trailer-connector.jpg
So, "normally", plugging one into the other should do it. However, I used a voltmeter and there is no power coming from both flasher/brake wires. I verified in fuse box and trailer fuses are all there and Ok (in fact, they are the same than vehicle flasher/brakes). So, I guess there is a missing relay somewhere that is normally part of Ford Escape Towing package. If I could find that part number, that may help.
Thanks in advance again !
Denis
http://pages.infinit.net/dsa/Pics/DSA_Escape_mini.jpg
Old Mar 16, 2002 | 07:08 PM
Mil1ion's Avatar
Mil1ion
Sorry, I thought you got a aftermarket connector to the trailer Not a ford connector that went out past the truck.
Is there power to all the wires BEFORE the part you just plug in?
84 Volvo DL Wagon
Old Mar 16, 2002 | 07:23 PM
dsa's Avatar
dsa
[updated:LAST EDITED ON 16-Mar-02 AT 08:29 PM (EST)]Honestly, I did not verify. However, some other Escape owners did report same issue. Most of them got discouraged and bought aftermarket "T" connectors including separate converters.
As I'd really prefer to have a complete Ford solution, I continue searching.
If only I could have detailed content (with part numbers) of Ford Escape Towing Package ! I'm sure the answer is there.
Thanks for your help !
Old Mar 19, 2002 | 09:07 PM
dsa's Avatar
dsa
[updated:LAST EDITED ON 19-Mar-02 AT 10:12 PM (EST)]Problem solved !!!
Bottomline, if you want Escape factory trailer wiring, you'll need:
YL8Z-13A576-AA Factory wiring assembly
YL8Z-13350-BA (or YL8Z-14N089-BA) Flasher module "supporting" Factory wiring.
Denis
2002 True blue Escape XLS
FWD / 4 cyl. / man. trans.
Old Mar 19, 2002 | 10:36 PM
Mil1ion's Avatar
Mil1ion
Old Jan 19, 2010 | 06:37 PM
chupacerveza's Avatar
chupacerveza
YL8Z-14N089-BA
Can this part be had for less than the $77 my local dealer is asking?
I'm "upgrading" my 2002 Escape FWD and have also found that I have only running lights with the Ford trailer harness, so I need to change the flasher module (from the blue one to the yellow one) to get brakes and turn signals on the trailer lights.
Denna
Escape & Escape Hybrid
Nov 24, 2014 11:28 PM
gcarmigl
May 2, 2014 03:22 PM
guitarmusiczone
Jan 7, 2014 10:33 PM
tabbie8372
Jul 26, 2010 07:55 AM
martin_csr
Jul 6, 2010 12:15 AM
