fe smokes, good compression
Old Aug 12, 2008 | 06:49 PM
todd jo's Avatar
todd jo
I have what is presumed to be a 352 swapped into a 73 4x4. It has headers and what looks to me like a carter afb. I ran a compression test on all cylinders. The lowest cyl. was 154psig. and the highest was 169psig. I was amazed the compression was that good? The thing smokes out the tailpipes like crazy, real annoying to me. I put a mech oil pressure gauge in too, very low pressure at idle when the engine was warm. It was about 5psig. At 1200 rpms the pressure was at 20psig.
I set the dwell to to 29 degrees, I didnt know the proper angle? I found autolite 124 plugs in it. Tomorrow I will replace the oil with straight 40wt. The plugs are being replaced with autolite 85 plugs, along with new wires. The cap and rotor appear to recently replaced so they will stay as is for now.
Fe FAQ leads me to believe there are oiling problems, but the mods suggested do not indicate the problem in my peabrain.
Is there something else I should check out that is simple for the home garage guy with decent tools?
Thanks, Todd
Old Aug 12, 2008 | 07:40 PM
ihateminimumwage's Avatar
ihateminimumwage
What color is the smoke?
Old Aug 12, 2008 | 07:44 PM
60F100's Avatar
60F100
First make sure the smoke is oil and not coolant. If it has an automatic make sure that it is not sucking ATF thru the vacuum modulator. When you pull the plugs look at them to see if any or all are dicolored like it is burning oil. Most service manuals have pictures of how to diagnose the looks of a plug.
Old Aug 12, 2008 | 11:11 PM
85e150's Avatar
85e150
Coolant: white smoke, mostly steam
Oil: Blue
ATF: Light blue, really stinky.
Overrich: Black, with blue as the oil is washed off the cylinder walls.
Could be the valve seals/guides.
Also check the pcv, make sure it's working and not sucking oil.
Modulator is a good place to start as per prior suggestion.
Good luck.
Old Aug 12, 2008 | 11:25 PM
todd jo's Avatar
todd jo
Np-435 so we can rule out ATF. Could water enter the exhaust stream even with the compression readings I got? It would have to come through the head in a crack or bad head gasket. Is this correct. The smoke was worse on cyls 1-4. I think I would call the smoke blue?
Todd
Old Aug 12, 2008 | 11:36 PM
Bear 45/70's Avatar
Bear 45/70
Bad valve seals, they have gotten hard, possibly broken and no longer work. It's a normal deal with the umbrella style of seals on FEs.
Old Aug 13, 2008 | 11:57 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do the old 3rd gear (435NP) run up to 4500RPM, let off, coast back down to 1000RPM, and hit it again. Is there a big POOF after you hit it again?
Intake gasket leaking.
Old Aug 14, 2008 | 12:46 AM
todd jo's Avatar
todd jo
I replaced the ignition parts and changed the oil. The oil pressure rose as expected and the engine runs much smoother. Still smokes more than I like. Still seems to be from the 1-4 bank.
Tried a road test tonight, but the bell or pot joint on the end of the steering shaft needs repaired so the drive was cut short.
Todd
Old Aug 23, 2008 | 12:07 AM
orich's Avatar
orich
The aftermarket replacement shaft for the steering shaft is not cheap any more. Ford stop using those little upper u-joints unless you can get lucky. and someone has a good one for sale.. they were about $300 the last time I saw them going for..my 2cents
orich
Old Aug 23, 2008 | 07:10 AM
Argess's Avatar
Argess
As above, (I agree with the other guys), however here's a couple more checks:
Try disconnecting your PCV line and see if the smoking stops. Maybe a new PCV valve is req'd. (My manifold only allows PCV fumes into 1-4 bank)
If it doesn't, check the plugs for oily ones. Try disconencting the wires for those (oily) sparkplugs (assuming it's only one or two) and see if the smoking stops. In that case, you may have a leaking intake manifold gasket.
Dirtscooter250
Jun 9, 2016 09:13 PM
Jonota
Sep 7, 2015 03:21 AM
bismic
Aug 26, 2011 08:53 PM
todd jo
Oct 11, 2010 10:47 PM
Forest
Feb 25, 2009 08:51 PM
