And Yet Another C6 Question
Old Aug 12, 2008 | 03:49 PM
big1's Avatar
big1
I have recently converted my 77 F100 from the 300-6cyl to a 351W.
I rebuilt both the engine and transmission. They came from an 83 E350 utility truck.
After installing the transmission I realized that it was leaking. I had fogotten that it had been sitting for nearly 3yr's. so the seal was probably dry. No big thing. I changed it. Reinstalled the transmission. Now after adding about 8qt's of fluid it leak's yet again. Since this I've changed pump's, bushing's and seal's. The servo opening has been tapped and plugged. I even went so far as to change case and still it leak's. The block dowel's are new and the flywheel is new as well. What on earth can it be that I'm over looking???
richartdana44
Sep 12, 2010 09:06 PM
beechkingd
Aug 25, 2008 06:15 PM
afinepoint
Feb 18, 2007 04:07 AM
bradcdavis00
Aug 12, 2005 07:47 PM
msmarcus
Apr 6, 2001 11:10 AM
