Transmission Leak
Old Apr 5, 2001 | 06:41 PM
msmarcus's Avatar
msmarcus
Transmission Leak
Need some help. I have a 1979 F350 w/ 460 and c6 auto trans. I had a leak that appeared to be coming around the transmission pan, so I had the seal replaced last friday along with the fluid and filter. Transmission was dry as a bone through today. Now looks as though the seal is leaking again. Only thing is that yesterday I did not move the vehicle, but did let it run for about 20 minutes in park. Not sure why it would be leaking. Can it be leaking from another area and appearing as it is coming from the pan/seal. Any ideas will be gladly accepted.
Mark
Old Apr 5, 2001 | 08:20 PM
rwjr's Avatar
rwjr
Transmission Leak
if the leak is on the driver's side, it could be the shift lever seal, passenger side it could be the servo cover, back it could be the extension housing seal or modulator. otherwise, if it really is coming from around the pan, the lip of the pan could be bent or the pan could be overtightened, causing the gasket to leak.
Old Apr 5, 2001 | 08:21 PM
rwjr's Avatar
rwjr
Transmission Leak
also check the dipstick tube...they tend to leak as well
Old Apr 5, 2001 | 09:25 PM
oz9609's Avatar
oz9609
Transmission Leak
Get a can of choke cleaner and clean it off real good and dry. Let it sit for a few hours and trace the leak to the source.
Old Apr 6, 2001 | 06:36 AM
dzjammer's Avatar
dzjammer
Transmission Leak
Another guess would be if it is coming out of the front shaft seal. I had that happen and when it does, the torque converter throws the oil all across the front before it seeps down out of the cover. I fixed mine with a new seal and repair sleeve on the converter.
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
Old Apr 6, 2001 | 09:47 AM
beartracks's Avatar
beartracks
Transmission Leak
I replaced the pan gasket twice on mine before I realized it was the shift shaft seal. Clean it off good and check it daily for a couple of days. You may see fluid on the shift lever. Mines going to a shop to fix. Don't have time or patience to pull the valve body to replace the seal.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Apr 6, 2001 | 11:10 AM
50yellowbeast's Avatar
50yellowbeast
Transmission Leak
RustyBeach77
1997 - 2003 F150
Jul 19, 2012 01:16 PM
richartdana44
Sep 12, 2010 09:06 PM
MagKarl
Jul 15, 2010 09:43 AM
fordno1
1978 - 1996 Big Bronco
Jul 6, 2009 08:28 PM
Gunpowderboy
Mar 19, 2004 04:42 PM
