help needed
Old Aug 12, 2008 | 08:02 AM
bill1187's Avatar
bill1187
help needed
does any one have a link on how to do the ccv mod and how to make a boost leak tester or can i buy one my turbo boots are weeping oil and truck doesn't seem to have the ***** it once had thanks for any help guys
Old Aug 12, 2008 | 08:11 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
This will get you started.
Welcome to guzzle's CCV mod web page
Old Aug 12, 2008 | 08:15 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Mark gave you the link for the CCV mod. For the leaky boots, take them off and give them a good cleaning then install them and tighten them just enough to stop any leak. Don't forget the ones under the spider, they are orange.
Old Aug 12, 2008 | 08:16 AM
zx250's Avatar
zx250
Of the next Riffraff East
The first post at the top of this forum will address most of questions you can come up with. Several site sponsors at the top sells the boots, although one leaking oil is more likely loose and needs to be removed, cleaned and reinstalled, tightly. Check all of them for fit and tightness. Leaking boots will shrink most diesel *****.
Old Aug 12, 2008 | 08:20 AM
mueckster's Avatar
mueckster
Look here for info on a "homemade boost leak detector": https://www.ford-trucks.com/forums/6...-detector.html
Old Aug 12, 2008 | 07:47 PM
bill1187's Avatar
bill1187
thanks for all your help guys
Old Aug 12, 2008 | 08:30 PM
danskool's Avatar
danskool
Go Bills !
Found on this site. Forget who posted.
This is how i made mine. Used hand grinder to ruff up edge were it gets tightened down.
4" 45`elbow. and Cap
It slipped out once and almost shot me in the face. Loud POP. Had folks come running to see if i was ok. Tool was at the other end of the garage. Still attached to the air compressor hose.
say, 4.00"bore x.4.00"bore = 16 , 16 x .7854 = 12.57, 12.57 x 20psi = 251lbs +- of force trying to push that tool off and knock you teeth out. Use caution.
http://i233.photobucket.com/albums/e...l/leaktest.jpg
Old Aug 12, 2008 | 08:49 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
didnt know you could square it and then multiply by that... learn something every day!
Old Aug 13, 2008 | 06:28 AM
bill1187's Avatar
bill1187
i'm looking at getting new boots i found them for $115 and $80 for the clamps does anyone know of any cheaper?
Old Aug 13, 2008 | 07:43 AM
Ponyboychris's Avatar
Ponyboychris
How about here:
http://www.dieselsite.com/index.asp?...ROD&ProdID=133
Old Aug 13, 2008 | 08:23 AM
crum71's Avatar
crum71
1/8 mile Oval Track
What about these? The site also has the clamps.....much cheaper
Straight Sleeves - Silicone: Intake Hoses, IntakeTubing, and Intake Clamps
Old Aug 13, 2008 | 08:47 AM
zx250's Avatar
zx250
I think I have heard that silicone is not rated for oil and fuel.
Old Aug 13, 2008 | 08:58 AM
crum71's Avatar
crum71
1/8 mile Oval Track
Yeah this is true, I just got done reading about that, anyways,you can get the clamps cheaper lol..... Thanks for correcting me Barry
Old Aug 13, 2008 | 09:03 AM
zx250's Avatar
zx250
Still a good price and I think the stock boots are silicone anyway. Mine has lasted for 150k if they are silicone. The ones from dieselsite are the best, but don't include the CAC boots which are another $129.
