home made boost leak detector
Old Apr 25, 2007 | 02:33 PM
Mike F250's Avatar
Mike F250
I've been searching for a while now and cannot locate and pics or instructions on how to make a boost leak detector. From the pic on dieselsite and someone's suggestion to use pvc, it looks pretty simple.
Any one have pics of one they made? lessons learned?
Any reason I should not use a schrader valve other than less airflow?
Old Apr 25, 2007 | 02:42 PM
Tenn01PSD350's Avatar
Tenn01PSD350
It looks way easy to make. The gauge can be bought at Wally, one for a compressor, dirt cheap. As for the schrader, just pull the guts out and put the chuck to it. I will be making one one day just for the halibut. I will go to Lowes for everything else as they have everthing else needed..
Old Apr 25, 2007 | 06:52 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It is as easy as it looks. One minor hang-up I had was I used a reducer hose for RV plumbing, which is larger than the 4" marked on it, so it has to be clamped down very tight to hold. Other than that it works great.
Old Apr 25, 2007 | 06:56 PM
Tenn01PSD350
That's even simpler Scott. I assume you just use the compressor gauge and valve. After thinking about it, who needs one on the unit anyway? We're looking/listening for a leak.
Old Apr 25, 2007 | 07:00 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep. I just crank the regulator on the tank down to about 40 psi and let 'er rip. If there are system leaks they become obvious almost instantly.
Old Apr 25, 2007 | 09:53 PM
jtharvey's Avatar
jtharvey
Does the engine hold the air, or will some of it leak out past some valves, possibly spinning a dry turbo?
Old Apr 25, 2007 | 09:58 PM
cookie88's Avatar
cookie88
FTE Emeritus
It holds it. Can't leave the test valve open for more than a few seconds as all the boots start to swell.
Old Apr 25, 2007 | 10:00 PM
John311t's Avatar
John311t
I would imagine it really couldnt leak past the valves, if the intake valve was open the exhaust couldnt be open at the same time and visa versa.
Old Apr 25, 2007 | 10:17 PM
jtharvey's Avatar
jtharvey
I just thought if you happened to catch a cylinder when there was some overlap in the intake valve opening and the exhaust valve closing, you might get some air past. But, I don't know the cam grind on our trucks either and if there's much overlap at all.
Old Apr 25, 2007 | 10:22 PM
Tenn01PSD350
Seems nobody knows this but it seems that all agree there is no money to be made grinding a new one as I have yet to see one. Anyone?
Old Apr 25, 2007 | 10:31 PM
bdrummonds's Avatar
bdrummonds
I read somebody over on TDS had experimented with a different cam but the outcome was not nearly as good as the stocker.
Old Apr 25, 2007 | 10:47 PM
jtharvey's Avatar
jtharvey
Nothing seems to work yet. Several grinds have been tried, but like BD said, nothing has seemed to work as well as the stocker.
Old Apr 25, 2007 | 10:53 PM
luvemhot's Avatar
luvemhot
Bought all the stuff to make mine the other day and my taps are not big enough. gong to stop and get a bigger one tomarrow on my way home from work.
Keith
Old Apr 26, 2007 | 07:41 AM
Mike F250's Avatar
Mike F250
Wow, very simple! Thanks Scott! I never thought about using my boost guage instead of buying another pressure guage for the tester.
The comments/questions in regard to valves and boost going through other places... I had thought about that too. I guess teh best way to learn is to do it.
Thanks for the input
Old Apr 26, 2007 | 08:30 AM
Tenn01PSD350
I believe he was talking about the gauge on the pressure regulator on the actual compressor but I suppose someone could watch the vehicle boost gauge too. I wouldn't want to jam 80 PSI in there accidentally.
