better check this out...
Old Aug 12, 2008 | 08:51 AM
hdman6's Avatar
hdman6
Exclamation better check this out...
My brother has a 2001 psd. I have a 2002 psd. He just repaired his powersteering pump lines. Here is the problem. (driver side wheel well)The rubber lines from the pump run along the frame and behind the shock area (2 lines) They rub on the metal part of the frame and eventually wear a hole through the lines from the constant rubbing action between the frame and the rubber line. When it wears through the power sttering fluid goes all over and you loose you power brakes and steering all at once, this is what happened to him. So I checked mine out today and sure enough i have a good portion missing from the constant rubbing action that is going on. What I am doing is putting some plastic hose protector over my hoses. Hopefully this will prevent any problems like this from happening. So betyter have a look guys and save yourself a big headache... Jeff
Old Aug 12, 2008 | 08:56 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thanks for the reminder. We do need to have these every once and a while. .
Old Aug 12, 2008 | 09:05 AM
danskool's Avatar
danskool
Go Bills !
I will check that out tonight. Thanks
Old Aug 12, 2008 | 09:19 AM
Hiflyer746's Avatar
Hiflyer746
Good call. . . I'll check it out immediately. Somebody rep him because thats useful information that could save us money down the road.
Timmy
Old Aug 12, 2008 | 09:24 AM
Mike Norwood's Avatar
Mike Norwood
Timmy
Done, good catch. I just replaced my power steering gear box, but I never really noticed anything, guess I'll have to check.
Old Aug 12, 2008 | 09:30 AM
miller_feed
I gave him a greenie too. Good info.
Old Aug 12, 2008 | 09:55 AM
Ponyboychris's Avatar
Ponyboychris
thanks, on my check list for the weekend maintenance.
Old Aug 12, 2008 | 09:59 AM
parkland's Avatar
parkland
reps given, i'll be checking mine...
Old Aug 12, 2008 | 10:21 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Reps given here as well, thanks and good catch.
Old Aug 12, 2008 | 10:27 AM
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3
Good catch and report, rep points sent.
Old Aug 12, 2008 | 10:56 AM
03_PSD's Avatar
03_PSD
great heads up....greenies on the way!!
Old Aug 12, 2008 | 01:24 PM
AustinS's Avatar
AustinS
Another green coming your way. No, it's not cash.
thanks,
Austin
Old Aug 12, 2008 | 01:40 PM
whjco's Avatar
whjco
Be sure and check the flex portion of your brake lines while you're at it. The one going from the antilock unit to the left front wheel vibrated through and blew out on my 2000 Ex a couple of months ago. Fortunately, I was bleeding brakes after changing pads and rotors and wasn't moving when it happened, but I was a little puzzled for a few minutes when brake fluid started running out of the front of the truck.
Old Aug 12, 2008 | 03:21 PM
Kwikkordead's Avatar
Kwikkordead
Thumbs up
I'll check mine today as well.
Reps sent.
Old Aug 12, 2008 | 03:27 PM
ron's power stroke's Avatar
ron's power stroke
nice reminder...i was told about this last summer...i took my kids old bike tire..cut it about a foot long and zip locked it on both hose around the shock tower.....working great so far.. keep in mind these hoses do move when pressure runs though them..make sure you have enouph room for them to move...
