95 F150 Can't pull codes (EECIV)
Old Aug 12, 2008 | 04:42 AM
marragtop's Avatar
marragtop
I have a 95 F150 4.9, 5spd, 160k miles. CEL came on this past weekend so I went to pull the codes (OBDI/EECIV). I hooked the reader up to the port and I get nothing. It doesn't cycle the system, it just sits there and returns nothing. Same result with KOEO and KOER. I know the reader is good since I also have a 95 Explorer and it works fine on that. I'm assuming that I'm not getting the correct signal(s) to the OBD port. How can I further diagnose this? thanks
Old Aug 12, 2008 | 04:48 AM
EPNCSU2006's Avatar
EPNCSU2006
Hold the clutch to the floor while performing the tests and see if that makes a difference.
Old Aug 16, 2008 | 05:47 AM
marragtop's Avatar
marragtop
Holding the clutch down didn't make any difference. Does anyone have a procedure for testing the connections at the OBD I plug(s)?
Old Aug 16, 2008 | 07:44 AM
subford's Avatar
subford
Does the fuel pumps run all the time the key is on with the engine NOT running?
Old Aug 16, 2008 | 08:59 AM
marragtop's Avatar
marragtop
No, fuel pumps are working properly in that it primes for a second or 2 when you turn the key on.
Old Aug 16, 2008 | 09:01 AM
Conanski's Avatar
Conanski
See the proceedure here to pull codes without the reader..
Ford Fuel Injection
greystreak92
1978 - 1996 Big Bronco
Feb 19, 2013 02:16 PM
Jules3084
Jun 19, 2011 09:04 PM
bigdog95
Engine Swaps
Oct 4, 2010 02:22 PM
jaystroker
15
Oct 30, 2007 10:55 PM
silvapain
3.0L V6
Nov 24, 2003 11:18 AM
