1995 F-150 code 95
Old Jun 18, 2011 | 02:24 PM
Jules3084's Avatar
Jules3084
1995 F-150 code 95
Can someone please advise. A code 95 won't clear with either front or rear tank switched in.
The truck runs on either tank. I can hear and measure them when the key is turned.
The sense wire to Pin 8 of the EEC-IV measures good to the fuel pump relay contact.
Seems like I'm missing something here.
Old Jun 18, 2011 | 05:53 PM
Jules3084's Avatar
Jules3084
There is also a code 53 and 22 that don't clear the KOEO test.
The MAP sensor and TPS have been replaced. Wires teso ok for continuity back to the EEC-IV.
Does anyone have any ideas?
Old Jun 18, 2011 | 06:56 PM
subford's Avatar
subford
First off the 1995 F150 do not have two number codes, they only have three.
So try again with the codes.
Second you can not clear a KOEO code, you can only clear CM codes.
CM = Computer Memory.
Old Jun 19, 2011 | 09:04 PM
Jules3084's Avatar
Jules3084
Thank you so much, that would explain it. I'll try again.
jerwiltho
Aug 15, 2013 04:00 PM
jsmorris
Dec 3, 2010 06:33 AM
bnkrtstk
Nov 6, 2007 05:37 PM
carbonmetallic
16
Sep 11, 2007 10:35 AM
LoosMaster
16
Mar 30, 2006 11:55 AM
