Sponsored by: Auxito
F150 with EXpy over head trip computer?
Old Mar 11, 2001 | 10:10 AM
turbo497's Avatar
turbo497
I want to replace my overhead display with the expedtion overhead trip computer because is does MPG, range gallons in tank, etc Has anyone done this yet and does anyone have one they would like to sell to me. Thanks Mike
Old Mar 11, 2001 | 10:54 PM
yjtrendsetter's Avatar
yjtrendsetter
Quite honestly, it will be impossible to get it to work. The TripComputer has it's own module, that is programmed in to the drivers door module. Unfortunatly just will not work together. Wish I could help you, but I can't. (Ford Mechanic)
YjTrendsetter
Old Mar 12, 2001 | 09:18 AM
turbo497's Avatar
turbo497
[font size="1" color="#FF0000"]LAST EDITED ON 12-Mar-01 AT 10:29 AM (EST)[/font][p]Hi trend, since you are a ford mechanic I would like you to take a look the splice schedule I pulled from the wiring daigs to see if they should work
well here goes for anyone who is technically cabable this is the splice schedule for the C928 connector that plugs into the OTC computer( this is the one with range, MPG, gallons in tank, and compass.
Pin#1 NOT USED
Pin#2 CKT702(WH/BK) splice to c905 pin#4
Pin#3 CKT703(WH/OR) splice to c905 pin#3
pin#4 CKT 71(OG/LG) splice to c174 pin#43
pin#5 CKT679(GY/BK) splice to c157 pin#3
Pin#6 NOT USED
Pin#7 CKT 53(BK/LB) splice to C242 pin#20
Pin#8 CKT434(LB/BK) splice to c283 pin#4
Pin#9 CKT705(LG/OG) Splice to c243 pin#32
Pin#10 Not used
Pin#11 not used
Pin#12 CKT729(RD/WH) splice to c283 pin#6
Pin#13 CKT875(BK/LB) splice to C905 pin#1
pin#14 ckt1003(GY/YE) SPLICE TO C905 PIN#2
PIN#15 CKT29 (YE/WH) SPLICE TO C237 PIN#3
PIN#16 CKT204 MARKED AS GROUND SPLICE TO GROUND?????
PIN#18 RIGHT MAP INTERIOR FEED CKT403(LG/VT) C245 PIN#2?????? OR C242 PIN#22
PIN 19 SAME AS 18 ONE FOR LEFT AND ONE FOR RIGHT.
PIN#20 NOT USED
The wire colors to the coresponding splice schedule match the colors listed off C928 If you start project and wires are not the same please email and I'll check diags again
It looks like this module does not handle the outside temp from the ambient temp sensor in the front grille of the truck. it looks like it is moved into the electronic climate control module. right now my over head module has compass and temperature on I may want to run both modules in tandem until I install electronic climate control
as far as being wired to the rap module I don't see that in the daigs. the rap has ckts, 267,7,1013,120,956,1090,875,66,268,1,119 on connector 257
and ckts 164,70,78,79,122,123,999,140,124,121,1090,1002,810 on connector 256 Please explian????
Old Mar 13, 2001 | 01:28 AM
knuckles's Avatar
knuckles
I have the factory manuals on CD-ROM, so I'd be glad to pull the diagrams & look for myself. Please tell us what year your truck is & what year the donor Expedition OHC is coming from.
Old Mar 13, 2001 | 08:23 AM
98screamer's Avatar
98screamer
thefnswits
Sep 21, 2008 03:28 AM
totavikid
Nov 1, 2007 04:08 PM
shadowdd
Sep 29, 2007 10:44 AM
xp8103
Nov 13, 2005 03:26 PM
chefbill
Nov 12, 2001 02:28 PM
