What tranny?
Old Aug 11, 2008 | 08:06 PM
CDF302v8's Avatar
CDF302v8
What tranny?
Hey,
Does anyone know what transmission a 85 ford f150 have, it is a 4 speed overdrive...
Old Aug 11, 2008 | 08:16 PM
CE-f250's Avatar
CE-f250
The easiest way to figure out what trans you have is to get the VIN number and put it through the VIN decoder here on the site.
Old Aug 11, 2008 | 08:51 PM
CDF302v8's Avatar
CDF302v8
Thanks, but i tried that and it didnt say,,,
Old Aug 11, 2008 | 09:29 PM
quaddriver's Avatar
quaddriver
4 speed with overdrive or 4 speed incl overdrive? if the latter, most likely the T170 SROD RUG
Old Aug 11, 2008 | 09:43 PM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
Automatic/w od would be an AOD. does your selector say P/R/N/od/D/1 if it does, no 2nd gear selection its an AOD
and the trans pan will be pretty square with METRIC stamped on it
Old Aug 11, 2008 | 10:06 PM
CDF302v8's Avatar
CDF302v8
Thanks, Yes it does say that...P/R/N/OD/D/1, and it says metric on the pan...so you must be right. Thank you!
Old Aug 11, 2008 | 10:21 PM
CDF302v8's Avatar
CDF302v8
Is it a good transmission?
Old Aug 11, 2008 | 11:29 PM
northern 7.3
not if you wanna tow or hot rod the engine. for a stock pickup that you haul a load of leaves to the dump and crap like that they work fine. i had an 85 with a 302/AOD. It had high miles and it and i never had to rebuild it. i didnt tow very much with it, i dont think the previous owner(s) did either. only a flat 4 wiring hook up and no reciever hitch. my old man has an 84 with AOD too, never been rebuilt, also not too much towing. both 2wd's
Old Aug 12, 2008 | 08:48 AM
shadylane's Avatar
shadylane
The AOD is good for gas mileage, but a C6 will out last several motors.
Old Aug 12, 2008 | 06:04 PM
85e150's Avatar
85e150
Early AODs are troublesome. '88-93 had some or most of the issues fixed.
If it is working ok, best let it be. If you want to make some changes, these transmissions can be improved and beefed up.
Sites that sell parts and transmissions. They also have info on the trans:
AOD Transmission from PATC, AOD Transmissions
AOD Performance Products - Baumann Electronic Controls
www.CKPerformance.com
TCI - Ford AOD, AODE and 4R70W
TCI has the most info imo.
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
SuperSnake
Maryland Chapter
68
Jul 9, 2008 12:17 PM
JByrd1173
Dec 11, 2004 03:35 AM
3.8 & 4.2L V6
Jan 23, 2003 10:01 AM
bigsnag
Nov 22, 2001 10:35 PM
