ok, I updated my 95 5.8 4x4 to a 96 ecm.
Othe than having to make my own harness, I also had to buy 2 new o2 sensors and weld in bungs.
I also had to buy a special 1 yr make harmonic balancer with a tone ring on it. I also had to install a pickup for it as well as install a OBD-II port.
I was able to remove the smog pump as well as the lines that go to it, and I plugged the back of the heads. I did not install a rear (3rd) o2 sensor after the cats however, as I don't believe that has anything to do with mileage or performance, I think it just checks the effiency of the cats.
The one thing I did remove and need to re-install is the EGR valve. I need a new one and a DPFE sensor, but do not know how to install it. I just disabled it with a tweecer.
That's not typical.. an improvement in milage is what I see reported most times.. though it's not always a hugh improvement. What about the EGR valve are you having trouble installing? The lack of EGR will definitely impact milage, and how exactly are you calculating the milage?
calc mileage as full tank to full tank. Trip meter miles divided by gallons to fill.
but I mean I was always able to get over 220 miles out of the front tank and now I can't even get 170. It is rather pathetic.
The new 96 computer requires a DPFE, my old 95 computer had a smog pump and a bunch of solenoids and air lines. I have removed all of that. I need a diffirent egr valve as well as a dpfe sensor. I need to know how to route the vacuume lines and I need a new vacuume canister. Once I have all that info and parts I can re-enable the EGR sensor on the computer.
I would think that even without the egr valve my mileage wouldn't have dropped off that much. Especially now that it is MAF calibrated and sequentially injected as opposed to port.
I wonder if a 95 ecm would have yeilded better results.
I am also debating if I have trully disabled all the info that the computer is looking for on the rear o2.
I am not sure, but there are a ton of scalars about it.
I am also wondering if I can get a better program, like a superchips burn, and insert that with the tweecer for better mileage.
I for some readon am getting abour 16 around town on a tank, and about 14 on the highway....
I am still assuming that it is the fault of the EGR.
Can I use the old egr valve, with the EVP or do I have to have a diffirent one and install the DPFE?
Chris
EGR is likely your problem because it reduces pumping losses at highway speeds. My Dad has a 96 Bronco with 5.8 and sucks gas like a banshee. He is lucky to get 14mpg with a tail wind. These computers might not be the best route for performance and mileage because of the OBD2 system.
Not normal course most woulkd have went with the obd! set up. Somethings off . We average 2-3 MPG increase on the 302 covnversions . And have had 351's running 302 MAf ecu still have MPG improvment.
more like 160 out of the front tank. I used to get 200+ when it was SD. I wanted to go to a 95 maf computer, but finding one for a 5.8 w/ E40d 4x4 just wasn't happening. Watched ebay for over a year.
I wonder if I can just use the old egr valve and the position sensor and just tell the ecu that is what it has. I mean I know how to with the tweecer, I just wonder if it will work correctly since there is no more thermactor junk on it.
Also, it smells like it is running rich, so something must be up. I cannot even spin my tires anymore either, so I am assuming very lame program in the computer. Might buy a programmer, just to see what I can do.
Well, I got the egr hooked back up, no signs of improvement yet
Do you think a 95 EEC-4 computer would be a better choice?
I only went with the 96 for the obd-2 port and the tweecer datalogging feature.
Normal chain of events is EGR gradually loads up internally & becomes less and less able to adiquitly respond to demands from the Pciency reduces And residue and carbon deposits increaseingly build on the surfaces of the combustion chambers.good news:as deposits increase and cylinder volume reduces this increases the rate of compression. Bad news: your 302 is only displaceing 289 c.i. at the moment. Residual fuel reminants are exausted where they collect on and around the O2 sens. causing it to respond less accuratly & at a reduced switch rate. and as a parting gift, clogs & poisons your Cat. 2 cans of SeaFoam. 2/3 can thru air intake 1/3 in tank, repeat again a week later. If EGR now ok, then replace O2 sens. w/hi switch rate unit, you can expect at least a noticable improvement until replaced by removeing & doucheing probe P/U head w/ electronic contact cleaner & reinstalling. Useing other than 87 octane will only contribute in makeing it worse and faster. Problem w/ EGR is by the time flow reduces flow to the point of throughinga error code, negetive effects are well established.
