Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Some good tips
Old Aug 9, 2008 | 12:07 AM
ford2go's Avatar
ford2go
Some good tips
I ran across this article in the ASA publication Autoinc.
It's a service oriented mag, and they have a lot of business stuff. However, they do have a couple of tech articles each month, and they are sometimes very interesting.
Anyway, here's the link
AUTOINC. ONLINE - Tips, Tricks that Work
I've run across a few of these situations, and I am but a poor grasshopper in the mechanical stuff.
Old Aug 9, 2008 | 11:43 PM
Chaosracing's Avatar
Chaosracing
Those are very good tips. Most I already knew, but I like the one for an inline fuse on the amp meter and the heat shrinkable butt connectors. Looks like Im gonna have to find some of those.
Old Aug 10, 2008 | 12:54 PM
Ford_Six's Avatar
Ford_Six
Most of those seem to be good tips, but one I would never recommend is using two hammers on the stuck rotor or drum screw; hammers are hardened and can shatter when hit together. I have had this happen and luckily it happened at work so when I had to get the chunk of steel removed from my hand and get all cleaned up I didn't have to pay for it.
Old Aug 19, 2008 | 07:33 AM
OzFTrucker's Avatar
OzFTrucker
One of the first things you get taught when you go to trade school as a first year apprentice is NEVER strike two hammers together, this guy is a "triple master certified technician"(whatever that means?) and he is recommending smashing two hammers together?
Old Sep 4, 2008 | 10:40 AM
Nitramjr's Avatar
Nitramjr
That is probably the only thing I remember from the 7th grade "manual training" class we took. Teacher (two fingers missing like any good shop teacher) had a big poster about not being a "Primitive Pete" by using the wrong tool for the job. The poster showed some monkeys hitting hammers together and using screwdrivers as chisels. Crazy what the brain retains 30+ years later......
In an extreme pinch, a block of wood works as a good buffer between two hammers being struck together.....
Old Sep 8, 2008 | 11:59 AM
4starcstms's Avatar
4starcstms
Actually hes not saying to strike two hammers together. Hes Suggesting you hold one hammer against the Screw and strike it with a second. Its not the same as smashing two together. If you can hit that screw and only that screw with a blow from a ball peen hammer... well I wanna see that. Its a good alternative and I have done this a few times. The World didnt stop, or spin off its axis, I didnt loose a finger or anything either.. Haha
I think its a good tip - IF You really dont want to use the second hammer method, use a blunt ended punch.. same theory, just make sure its small enough to only strike the screw head ... and nothing else.
Old Sep 8, 2008 | 09:04 PM
ididntdoit99's Avatar
ididntdoit99
I was always told the same thing, but I saw mythbuster do tests on this twice, and couldn't get them to break.
Now I run around all day smashing hammers together
Old Sep 9, 2008 | 05:57 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I saw that episode too... I wonder if today's hammers are designed not to do that, i wonder what the test would be like if they used hammers from 15 years ago...
Old Sep 9, 2008 | 04:13 PM
stryder's Avatar
stryder
Actually it does come down to hammers are not made like they used to be. Find and old Eastwing hammer and listened to it ring as you drive nails. Compare it to a new Eastwing hammer and you'll hear the difference. .
Old Sep 9, 2008 | 09:27 PM
ididntdoit99
I think they did that same test on two different episodes... the second time they used some OLD hammers, and they also heated them up and quenched them in used oil to make them more brittle. They still wouldn't shatter.
http://en.wikipedia.org/wiki/MythBus...mer_vs._Hammer
yeah, they were pre WWII steel hammers
Old Sep 11, 2008 | 05:32 PM
77f2504by4's Avatar
77f2504by4
beleive it or not, but i've never heard that "you shouldnt stike two hammers together" warning. after reading the above mentioned mythbusters tests, i dont beleive that anyone has ever done this and had there hammer "explode", but then again i've never tried or needed to try it.
Old Sep 11, 2008 | 07:34 PM
Nitramjr's Avatar
Nitramjr
I don't think they would explode at all but rather splinter or break. If they are they same hardness and you hit them together hard enough, something would have to give. That's why chisels and other tools meant to be struck are always a softer steel.
Old Sep 11, 2008 | 09:54 PM
77f2504by4's Avatar
77f2504by4
i dont doubt they could break if hit just right and with enough force, but what are the odds of that happening when your doing this and **NOT** wearing the propper safety gear?and to top it all off, there are weaker parts of the hammer that would most likely break first, like the handle. my point is that this is no where near as dangerous as originally posted. and hammers and striking tools have warnings that advise you to wear safety goggles for a reason.
Old Sep 12, 2008 | 11:15 AM
ghunt's Avatar
ghunt
I've also seen a lot of warnings about chisels, to say that if they're really mushroomed out to grind them down or they could shatter or splinter.
My dad has some of my grandpa's old chisels and hell, some of them look like mushrooms! But they've certainly never splintered. Not to say it can't happen, but I sure haven't ever really seen it.
Old Sep 12, 2008 | 07:37 PM
monckywrench's Avatar
monckywrench
"Hes Suggesting you hold one hammer against the Screw and strike it with a second."
I weld rebar handles to all my chisels and some of my punches. (The only logical reason they don't come with handles is expense.) My hand is out of the way, my control is improved, and it is easy to strike precisely.
