thermostat for the 400 engine
Old Aug 8, 2008 | 02:24 PM
Gaperkiller's Avatar
Gaperkiller
i have seen on this form and been told to only use a Cooper-Robertshaw thermostat. why is this brand the only one to use? is thier a problem with the NAPA autoparts thermostat? if so what is the difference?
Old Aug 8, 2008 | 05:09 PM
Rebel Warrior's Avatar
Rebel Warrior
I've never heard of that brand, I have never had a problem with Napa products. Napa thermostats are made by Stant, the one they call super stat is better in quality. although in my toy0t@ i had to use a factory unit, all other failed after a couple of weeks. Good Luck -RW
Old Aug 8, 2008 | 06:21 PM
unrulee's Avatar
unrulee
The ROBERTSHAW is the correct thermostat, I'm living proof...well maybe my truck is. I had an overheating problem, went to the "correct" t-stat and my overheating went away. Do a search on it, try the part # which I think is 333-192.
Old Aug 9, 2008 | 10:07 AM
fmc400's Avatar
fmc400
MSEE
I think it has something to do with the shape of the sides doesn't it? I thought I saw a diagram regarding that once. I don't have my 400 build book with me otherwise I'd try to look it up. Although I have a Gates thermostat in my 400 and it has worked fine.
Old Aug 9, 2008 | 11:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
351C/351M/400 Thermostat
As original: D0AZ8575A .. Thermostat-192 Degrees (Motorcraft RT139)
Still available from Ford: MSRP: $8.62.
Fits: 1970/82 351C/351M/400
This is the only T/stat listed for these engines.
A search thru several car & truck parts catalogs shows D0AZ8575A was not used with any other engines other than the original applications.
Old Aug 9, 2008 | 02:27 PM
firstonraceday's Avatar
firstonraceday
Unrulee was correct on the part no. for the Robertshaw t-stat. Here's a link to it at Flowkooler:
FlowKooler Water Pumps
Old Aug 9, 2008 | 05:29 PM
unrulee's Avatar
unrulee
Here's a comparision pic
The "correct" one is on right. Supposedly there is a bypass in the block that only works with the one on the right.
Old Aug 10, 2008 | 12:15 PM
RJR99SS's Avatar
RJR99SS
I just use that mr. gasket deal, even though for my purposes no thermostat would work.
Eddie C
Feb 9, 2016 07:00 PM
rascal1
Aug 22, 2014 05:56 PM
mustang81
20
Jan 15, 2013 04:10 PM
bgab3
Jan 5, 2013 08:17 PM
wtroger
Nov 20, 2003 10:14 PM
