Sponsored by: Real Truck
OBD-II With CAN
Old Aug 7, 2008 | 01:26 PM
SpringerPop's Avatar
SpringerPop
OBD-II With CAN
The current Harbor Freight catalog lists for sale an OBD-II Scanner with CAN.
It seems that the 6-oh's are CAN vehicles.
Has anyone tried this scanner yet?
Pop
Old Aug 7, 2008 | 02:39 PM
ReAX's Avatar
ReAX
CAN is Controller Area Network and not necessarily diesel compatible. CAN and Diesel have nothing to do with each other, it's just the way the components communicate with each other. For a diesel, you will need to find out if it can read diesel.
Old Aug 8, 2008 | 11:35 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, the CAN thing is going to give you airbag and ABS codes, doesn't it?
Old Aug 8, 2008 | 12:52 PM
skoveng's Avatar
skoveng
Check out AutoEnginuity - OBD2 with the Ford specific software - good stuff about $200 for laptop software and cable.
Old Aug 27, 2008 | 01:15 AM
Catman3500's Avatar
Catman3500
Can I just use this software to monitor the engine and scan codes and install tunes in my truck? Any other tips you have about this would be great. Sean
Old Aug 27, 2008 | 06:10 AM
projectSHO89's Avatar
projectSHO89
Nope.
CAN is simply a new communications network standard whose use is mandated on ALL US-market vehicles by 2008 (iirc). Ford started using it on 04 MY vehicles.
That means that your older scan tools and readers are worthless if you buy an 04 or newer Ford unless you can get an upgrade for it.
Steve
powersmoked
1983 - 2012 Ranger & B-Series
Mar 13, 2012 08:51 AM
CT
17
Aug 29, 2011 12:07 PM
mrplow
Computer Chips & Tuners
Feb 3, 2004 11:34 AM
mrossirr
May 17, 2003 05:39 PM
