EEC-IV or OBD-II?
Old Aug 25, 2011 | 10:14 AM
CT's Avatar
CT
Question EEC-IV or OBD-II?
Is my 1995 F-150 4x4 5.0L with 4R70W transmission EEC-IV or OBD-II? What can I look at to tell for certain? I read one comment that said Ford started phasing in OBD-II in some 1995s. The manufacture date is 5-95. I bought the pickup used and I think it has a replacement engine in it, there could be other changes as well.
There is a small grey open connector under the dash just above the transmission tunnel. Would that be the connection point for a scanner?
My transmission is giving me troubles. Is it controlled by the same module that controls the engine? Could it be upgraded to a newer year?
Old Aug 25, 2011 | 11:59 AM
kaduh's Avatar
kaduh
My '96 was built in Oct. of '95. It's OBD II and the plug is in the same place as yours. It's my understanding that the OBD II's are mounted here and anything prior, was in the engine compartment. I could be wrong though.
Silly question, but can't you just plug the scanner into the port and see what it says?
Old Aug 25, 2011 | 12:03 PM
andym's Avatar
andym
That is where the OBD-II connector is located. Yours could be OBD-II even though it's not "supposed" to be. What does the connector look like? Can you give dimensions? A clear pic would be conclusive.
Yes the same computer controls both the engine and transmission.
Pretty silly because if he already had an OBD-II scanner he likely wouldn't be asking where the plug is and what it looks like.
Old Aug 25, 2011 | 12:45 PM
Jaime74656's Avatar
Jaime74656
pics please, that will tell all...
Old Aug 25, 2011 | 02:13 PM
subford's Avatar
subford
A 95 should be OBD 1 not 2.
The plug under the center of the dash is for the brake controller.
Trailer controller plug:
OBD-1 Self-Test plug:
Old Aug 25, 2011 | 05:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your truck is not OBD-II. That didn't start on the F150 until 1996. The one EEC-IV PCM controls both the engine and transmission.
Old Aug 25, 2011 | 11:46 PM
CT's Avatar
CT
Thanks
Thanks everyone for the great information and pictures. I didn't even know I had a brake controller plug. Looks like I'll have to stick with rebuilding the transmission. I was hoping I could just drop in a newer year used one from a salvage yard. I had one located that was out of a low-miles wrecked 97 explorer.
Old Aug 26, 2011 | 10:56 AM
andym's Avatar
andym
I don't understand why you wouldn't have just asked if you could use a transmission out of a 97 Explorer then. The engine control system that your truck uses has absolutely nothing to do with whether the transmission will work or not.
What motor is in the Explorer? Is it 4x4?
Old Aug 26, 2011 | 02:27 PM
Mark Kovalsky
Why can't you? I don't understand.
Old Aug 26, 2011 | 06:51 PM
CT's Avatar
CT
EEC-IV or OBD-II?
The transmission I had spotted was from a wrecked 1997 Explorer 4x4 with a 5.0L. I know they are the same motor and both 4x4s, and the transmission has the same physical dimensions as far as I know, but my local Ford parts man told me the 97 transmission would be looking for electronic shifting instructions from OBD-II, and wouldn't work right hooked up to my 95's EEC-IV computer. I don't understand it, as I would think either ECU would send the same signals to the transmission. Just using caution and hearing all opinions, as the swap is a lot of work to get one in there and then not have it work right.
Old Aug 26, 2011 | 08:51 PM
subford's Avatar
subford
What the parts guy may be talking about is the clutches in the two years. The signal from the 95 are not the same as the 97 because of the type of clutches used.
It has nothing to do with OBD-I or II.
Old Aug 26, 2011 | 09:33 PM
Mark Kovalsky
He made that up. He has no idea of what he is talking about. OBD-II doesn't shift the transmission, the PCM does that. OBD-II is the diagnostics that runs in the PCM. You managed to find a parts guy that doesn't know anything about what he's selling.
Old Aug 27, 2011 | 05:30 PM
CT's Avatar
CT
EEC-IV or OBD-II?
I know parts guys are always slanted more towards selling new parts.
So if the electrical connectors are the same it should be a switch-n-go project? I haven't been able to look at the transmission since it is an out-of-state salvage yard. Any small upgrade or maintenance things you would do to a used transmission before installing it?
Old Aug 27, 2011 | 09:31 PM
Mark Kovalsky
There could be some pin location changes. It's been way too long ago for me to remember. If the electrical is the same and the trans came from a 4x4 5.0L Explorer it will bolt right in.
Old Aug 27, 2011 | 10:58 PM
Blurry94's Avatar
Blurry94
Should be more like EEC-4 vs. EEC-5. The EEC-5 ECU's of the OBD-2 type, and they may be pinned a little different.
