Oil Dipstick Problem 351C
Old Aug 7, 2008 | 12:31 AM
abelmoreno's Avatar
abelmoreno
Hello guys.
I purchased a Mr Gasket dipstick for my 73 351C 4V and it is not long enough!
The ring around the tube, where I guess it's supposed to rest on the block, does not lay flush on the hole on the block, if I do lay the tube flush on the block, I cannot use the tube to head mounting bracket because it wouldn't coincide.
Summit sent me another dipstick just in case, but it's exactly the same! (The dipstick box does read 70- 74 351C)
Am I missing something? a spacer? a gasket? something in between?
HELP PLEASE!
Anyone ever had this problem?
Thanks in advance,
Abel
Old Aug 7, 2008 | 01:56 AM
fozzy's Avatar
fozzy
I was noticing they make a 351C dipstick for entry into the block, and 351C dipstick for entry to the oilpan.
I wouldnt know the difference never had a cleveland.
Make sure you have dipstick out of tube before you mount the bracket, right? Theres always a catching point with the dipstick.
Good luck
Old Aug 7, 2008 | 06:46 PM
mark a.'s Avatar
mark a.
Can you post a pic ?
Old Aug 12, 2008 | 11:18 PM
abelmoreno's Avatar
abelmoreno
Tanks for the interest, I'll try to post a pic later on this week.
Old Aug 15, 2008 | 06:59 PM
abelmoreno's Avatar
abelmoreno
Hello,
Just FYI Summit has told me that the Mr Gasket dipstick has indeed a manufacture imperfection. They have compared one of these dipsticks with other manufacturers' and they are the only ones which are different.
I hope it's useful to know about it if you're planning on buying one of these for your Cleveland.
To sum up; stay away from part number: MRG-6922
Cheers,
Abel
Old Aug 15, 2008 | 07:05 PM
fmc400's Avatar
fmc400
MSEE
Thanks for posting that; hopefully you saved someone the hassle in the future.
351Cleveland C4
Sep 18, 2015 06:56 PM
maytea
15
Sep 15, 2015 02:40 PM
retroluxe
16
Jan 23, 2007 05:45 AM
